Results 1 to 10 of 10
Thread: Mounting a PC opposite a sub
    Low Bitrate Hacksaw's Avatar
    Nov 2003
    Southwest UK
    Lo all, I'm currently evolving my boot install and want to relocate my PC from the rear seat (hatch back) to a position where I can carry a bit more load.
    For a sub enclosure I have one of these "Stealth boxes":
    Clicky
    It sits in the boot (trunk) behind the rear wheel arch and is fairly flush with the parcel shelf support. (I'd get a pic of it in situ but the cars having it's MOT (road worthiness) test tomorrow.
    They make them for both sides, so was considering getting one and making a feature enclosure on the opposite side. One concern is that the kick from the sub might affect the PC (hard drive mainly).
    Any input on this?
    2000 Vauxhall Vectra SXi
    EPIA M12000 / 256MB RAM
    PW-120 + ITPS
    Slot Loading CDRW/DVD
    30GB 2.5in HD
    Lilliput 7" VGA + Touchscreen
    GPS Nav
    Installation progress {+++++++} (Installed! :) )
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Hmmm
    A speaker is a giant Magnet... Computers and magnets aren't very good friends... keep them away from each other..
    Jun 2004
    NH
    addition
    Add, you said in your orginal message that only the HDD.. but its actually more on the system board that affected... look for EMI materials and build them around the computer enclosure.. maybe that'll work..
    Nov 2003
    Southwest UK
    Ah, you missunderstand me.
    2 enclosures, one on the nearside of the car, the other on the offside.
    Theres a picture on the link which shows the 2 enclosures on opposite sides.
    What I'm concerned about is the air pressure causing the HD to skip as it would be firing directly towards it, albeit through a plexi window.
    PW-120 + ITPS
    30GB 2.5in HD
    GPS Nav
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    There are many people here with subs and computers in their trunks. I haven't heard of any problems directly related to the two being in the same compartment.
    ________________
    ______ILL.1______
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    your hdd will be fine if in doubt mount it solidly on the inside of the "spare" sub box using some wood screws ! 9you could get a few mouse pads and use them between the wood and the drive for extra isolation, the other alternative would be to get one of those hdd coolers and mount the drive in that and then mount the cooler to the box, probably easier to mount as well
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Nov 2003
    Southwest UK
    Thanks guys.
    PW-120 + ITPS
    30GB 2.5in HD
    GPS Nav
    Oct 2003
    Copenhagen, Denmark
    I have my pretty large sub (Crystex Emphaser 12") which is rated @ 1000Watts RMS right on top of my comp. case only 19mm wood between them and have never had any problems.
    Jan
    Not doing carpc anymore
    FLAC ppgt94's Avatar
    May 2001
    USA
    There are many post about this topic. Some queit extensive getting into much detail. I don't remember anyone having any problems with the speaker magnet or related vibration.
    Variable Bitrate fuctup's Avatar
    Nov 2004
    Minneapolis
    id try sound proofing, thick metel or cement case, depending on how hardcore you system is, and megnetic shielding.
    i had a friend with eight 10" subs and a large ppi amp, we had to soundproof his eclipse cd changer so the bass wouldnt make it skip.
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  3. Mounting PC Internals
    By djXternal in forum Fabrication
    Last Post: 09-28-2004, 09:34 PM
  4. mounting PC in trunk
    By animul in forum General Hardware Discussion
    Last Post: 09-04-2003, 01:20 AM
  5. Any problem mounting an inverter in the PC case?
    By lifeboat in forum General Hardware Discussion
    Last Post: 01-16-2002, 09:54 PM
