Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
Thread: COOLING THE CARPUTER
  1. #31
    May 2002
    Would be really cool to to build some logic that controls the peltier in a way that it allways keeps the system in a decent temperature.
    What you are suggesting is a thermal sensor much like the thermostat in your house. That can be rigged up with a microcontroller and a thermal sensor.
    In the winter time, just fire up the system and use it to warm up your car. Just a thought.
  2. #32
    Apr 2002
    Houston, TX
    Well this is an old thread that seams to have resurfaced... so I hope I don't state the obvious....
    But for cooling the case, what I did was install a Digital Doc 5 in the case which controls 5 fans.
    Fan 1 - In the Digital Doc, really doesn't do anything. Pulls air from car to inside the comp. case.
    Fan 2 - 120 mm, fan on the left bottom of the case, pulls air into the comp case from a hole in the car floor, so it pulls in outside air. A lot cooler than the case or inside the car.
    Fan 3 - Blows directly on the HD.
    Fan 4 - 120 mm on the right bottom of the case. Blows air out of the case through a hole in the car floor to the outside.... Exhaust the heat from the case basically and not into the car.
    Fan 5 - In the dash behind the LCD. Just to get some circulation up there. If I have problems with being to hot for the LCD I will hook into AC duct.
    The Digital Doc is the way to go (if you have a large case) cause all the temp. sensors and control circuits and setting ability is already there. Plus the display looks cool on the face of a case.
    Just a note my case is about 17" deep, 38" wide and 15" high. It sits in the back on the floor board under the hatch of a C4 vette, so I have plenty of room for stuff like this, you may not, but if you do it seems like a decent approach to me.
    Peltier's are neat things, but unless you exhaust them to the outside (of the car) you are wasting your time....
  3. #33
    May 2002
    Maybe you misunderstood what I wanted to say. When I said under the hood, I meant in the engine compartment. There it is exposed to fresh air; I think.
  4. #34
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Under the hood is probably too hot for a peltier cooler to be effective.
