Results 1 to 5 of 5
Thread: factory lcd display
    Newbie paradoxni's Avatar
    Jun 2004
    Antrim, Northern Ireland
    factory lcd display
    My megane has a small lcd display for time and track numbers etc. (when used with factory headunit) I have replaced my headunit and installed a carpc therefore this lcd only shows the time, is there anyway to hook the pc up to this to display tracknames etc?
    FLAC ppgt94's Avatar
    May 2001
    USA
    It is possible. Hell, almost anything is. Just depends on how much effort one is willing to put forth.
    You'd have to find out what format or protocol (ID3 Tag, etc) the factory system used to 'read' that info. Find where the data wires or pins are for the display. Map them to a serial port (or some kind of output) and send that info from your media player in that format... I think that's how it goes. I'm guessing really.
    Jun 2004
    well ive located the cable...behind the head unit as an extra connector in addition to the standard ones (also used for steering wheel stalk controls). Im willing to put in the effort, im just not that clued up on things like serial port mapping etc.
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    the easiest way, measure up that lcd, surf the web for one (matrix orbital / crystal fontz etc) and replace it with a pc one !
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Jun 2004
    yea that would be easier :P
  1. What is The best LCD display??
    By mikeee in forum LCD/Display
    Last Post: 09-04-2004, 10:51 PM
  2. Display OBD info on Serial LCD ? is this possible
    By SAScooby in forum LCD/Display
    Last Post: 07-20-2004, 06:35 AM
  3. Need an LCD controller for ex laptop display
    By MGP3Car in forum LCD/Display
    Last Post: 08-31-2003, 07:14 AM
  4. New 5.6" PAL LCD Display
    By WebAssistUK in forum LCD/Display
    Last Post: 02-20-2002, 07:05 AM
  5. Looking for Display 4x40 or LCD?
    By Squeeky in forum General MP3Car Discussion
    Last Post: 01-16-2001, 03:21 PM
