Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Quick release components
  1. #11
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    You could always get a low wattage heating unit. The same idea that they use to keep intakes warm, yanno you plug in your car when you get home? Alot of trucks have that feature, wouldnt be TOO difficult to add.
    RevFE
    My Shop
  2. #12
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    Malcom... the block heater in facts only heats the engin, not the carputer.
    Or course there are more changes the car would start, but yet again, the puter is not warmer.
    -Mars
  3. #13
    Jun 2004
    Westminster, MD
    I know, I'm saying run a line off of that to a heater element inside the computer case an lcd casing. So it turns on when you have it plugged in.
    RevFE
    My Shop
  4. #14
    Feb 2004
    Montreal
    Oh, a carputer heater plugged with the block heater... Could be a nice addition!
    -Mars
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    If only he could store the heat generated during run time for when the temperature drops during power down.
  6. #16
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    you could always just cut the cables
    seriously, cut the cables and get some mated connectors. doesn't matter compatability, as long as there are enough pins...
    If you make it removable, theives will have an easier time, but they will also leave your dash intact ..
    removable drive bay - good idea & cheap....
    I was actually thinking of creating a " Hanging " system for the lilliput... have button like hooks on the back of the screen case and then mount the opposing pins on the dash. It would just hang there and also could be removable for security reasons ( connectors for the cables - see above )
    hmmmmmm, back to the 3D CAD on this idea.......
    Don
  7. #17
    Feb 2004
    Montreal
    I have seen a plug for the outside that decides when to turn on depending on the temp. You simply plug your car and if its cold ennough it will power the block heater. If you have an extension cable from the block heater to the inside, you could have a small heater to heat the carputer at the same time..?
    I wonder about fire hasard, tough.
    -Mars
  1. Alpha Release: XMPC-CAR for XM
    By gork in forum Software & Software Development
    Last Post: 01-11-2006, 12:19 PM
  2. Quick release connectors for Touchscreen
    By Falken in forum LCD/Display
    Last Post: 02-01-2004, 12:04 PM
  3. need win 98 SE quick!!!
    By cubanmoses in forum General Hardware Discussion
    Last Post: 08-10-2003, 07:47 PM
  4. Does anyone in AUS have the coilcraft components???
    By odin836 in forum Power Supplies
    Last Post: 06-28-2002, 09:09 AM
