Results 1 to 8 of 8
Thread: anyone know the ide running temp for athalon 64?
    May 2004
    hey guys, just wondering if anyone knows what temp an athalon 64 3200+ should roughly be running at?
    Constant Bitrate sagekoala's Avatar
    Aug 2004
    Des Moines, Iowa
    i have the 1megl2 version that first came out and with the stock heatsink i think i normally run around 100-110*F
    don't worry i know i usually don't make much sense
    Constant Bitrate Avalerion's Avatar
    Jun 2004
    Hamilton, NJ
    h0t
    Jun 2004
    Hamilton, NJ
    And I really hope you're not putting a 64 in your car... Seems like overkill/waste. Use it on your own desktop.
    May 2004
    yeah, it is in my desktop...
    Avelerion - what do you term as hot? mine seems to be hanging around the 115 to 120 mark on idle with a Zalman CNPS7000B-ALCU cooler running on max fan speed!!
    what i'm trying to ascertain is whether this is correct behaviour... seems mighty hot for a CPU which isn't doing any work. but i have no previous experience with athalon 64's
    sagekoala - cheers... if yours is running that on the standard heatsink then mine seems to be running hotter than it should.... i've got some arctic silver 5 on order, so i'll see if that helps me at all
    if anyone has any suggestions for me it would be appreciated!
    Super Moderator xBrady's Avatar
    USA
    You aren't using any thermal compound on an Athalon 64!? Artic silver will definitely help.
    Installed.
    -GPSSecure- - GPS Tracking
    May 2004
    i am using thermal compound - the stuff that came with the zalman cooler...
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Bah. my athlon XP idles at 120 degrees F :-P 110 aint hot heh. At load my CPU gets up to 145 degrees.
    RevFE
    My Shop
  1. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 09:11 PM
  2. Found someting interesting on E-Bay!!!
    By outragis in forum Classified Archive
    Last Post: 01-23-2006, 08:38 AM
  3. Custom Length Round IDE Cables
    By antimatter in forum General Hardware Discussion
    Last Post: 08-17-2004, 12:23 PM
