Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 77
Thread: Pocket PC-based carputer idea.
  1. #31
    Nov 2004
    Albuquerque, NM
    Quote Originally Posted by Yuriy
    Yeah, but there are generic CF USB hubs out there, just plug it in and connect up to 256 devices to it
    Why wouldn't it be possible to use one of these to control a USB 5.1 sound card, hard drive, or DVD drive? Or by some miracle is it possible?
  2. #32
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    I've been using my Sony Clie NX80V as a "carputer" for quite a while. So far it foed everything I need it to.
    -GPS
    -Wifi
    -MP3
    -Video
    - And it has a great touch screen. (LOL)
    - O, and did I mention INSTANT on?
    I'll post pics asap. I just got my car back from the body shop. Someone crashed into my passenger side. F'ed it all up. I wasn't even in my car. Damn person didn't even leave a note. I was only parked there for like 25min.
    At least insurance paid to have it fixed and painted a different color.
    Peace,
    Rafster
  3. #33
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    there are some PC104 boards out there that have Xscale processors and will run CE and CE.net and they have multiple USB and sound etc ...... 3.5" x 3.5" big
  4. #34
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Finally got some pics up of my install with my PDA. Check my sig.
    Peace,
    Rafster
  5. #35
    Newbie panelrodder_81's Avatar
    Mar 2004
    Saratoga Springs, Utah
    The Asus A730W has built in WiFi, Bluetooth, SD, and CF slots and also ships from the factory with a cable the plugs in to the bottom for the BUILT IN USB HOST! I've been looking into this PDA for awhile I just can't convince my wife to let me get it! It is super thin, has a good battery, resolution is good and if I remember it is 400 mhz with 64mb. Might wanna check that out since it has the built in USB host. That is what caught my attention.
    PanelRodder
    PS: I had considered using one of the dells and just getting an extra cradle to mold into my car so you get in and put it in and walla, you are up and going! (More than that though! Stupid details!)
    Panelrodder
    1953 GMC Panel Truck
    2007 Pontiac G6
    2008 Chevrolet Silverado
    www.lunacium.com
  6. #36
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    The Dell Axim X50V has the option of VGA output. You connect something to the bottom of the uit, and youcan plug it in to any VGA monitor (640X480 Res)
    http://www.pocketpcthoughts.com/arti...n=expand,41409
    http://www1.us.dell.com/content/lear...=popup&ref=CFG
    It's got 624MHz, BT, Wifi, CF, and SD card. The only thing it doen't have is USB host, but as detailed below, you can get the in CF form. Seems like the Axim X50V is the perfect in car instant on solution.
    http://www1.us.dell.com/content/prod...=19&l=en&s=dhs
    Peace,
    Rafster
  7. #37
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Hardware Specs for Dell Axim x50V
    Processor
    Bullet Intel® XScaleTM PXA270 624MHz
    Operating System
    Bullet Microsoft® Windows MobileTM 2003 Second Edition with Windows Media Player 10 Mobile
    Memory
    Bullet RAM: 64MB SDRAM
    Bullet ROM: 128MB Intel StrataFlash® memory
    Display
    Bullet TFT Color 16-bit, Touch Sensitive, Transflective LCD
    Bullet 3.7 inches
    Bullet 480 x 640 resolution at 65,536 colors (VGA)
    Graphics
    Bullet Intel® 2700G multimedia accelerator with 16MB video memory
    Control and Lights
    Bullet 5-way Navigation button
    Bullet Wireless On/Off Button
    Lock Switch
    Bullet 4 Program Buttons: Calendar, Contacts, Inbox, Home
    Bullet Voice Record Button
    Bullet Reset Button
    Bullet Backlit Power Button
    Bullet Event Notification
    Bullet Charge Status
    Bullet Wireless Status
    Expansion Slots
    Bullet 1 CompactFlash Type II Card Slot (3.3v)
    Bullet 1 Secure Digital / SDIO Now / MMC Memory Card Slot (3.3v)
    Ports and Connectors
    Bullet Standard v1.2 (115 kbps) Infrared Port
    Bullet 36-pin Cradle/Sync Connector
    Bullet 3.5mm Headphone/Headset Jack
    Dimensions
    Bullet Length 119 mm (4.7 inches)
    Bullet Width 73 mm (2.9 inches)
    Bullet Height 16.9 mm (0.7 inches)
    Bullet Weight 175 grams (6.2 oz)
    Audio
    Bullet Audio Controller I2S Codec, WM8750 sound chip
    Bullet Stereo Conversion 16-bit stereo; 8.0, 11.025, 22.05 and 44.1KHz sample rate
    Bullet Full Duplex Record and Playback
    Bullet Integrated Microphone and Speaker
    Power Supply
    Bullet AC Adapter
    Bullet Battery Type
    Bullet 1100 mAh Lithium-Ion Removable, Rechargeable (standard)
    Bullet 2200 mAh Lithium-Ion Removable, Rechargeable (optional)
  8. #38
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    This is what I came up with a fully insured X50v with out extra stuff like SD card (Already have a 1gb for my camera that I'm getting rid of)
    Includes $229 BT GPS Mouse, and the VGA Presenter cable.
    Price does not include Lilliput.
    Kinda expensive, but it its instant on!
  9. #39
    Oct 2005
    Pocket PC as frontend for laptop
    I have gone through this post and a few others and what i am wondering is this -
    Is it possible to use your pocket pc as a touchscreen front end for you laptop in your car? If you could do that could you also play video on the laptop and have it play on the pocket pc also?
    I found this website which uses this software seems like it might kind of work.
    What I want to know is if anyone has done this maybe via terminal server connection or something.
    Dan
    Dell Axim X30
    Dell Inspiron 5100
    2002 Nissan Exterra (Needs Carputer!)
  10. #40
    FLAC jbors's Avatar
    Nov 2003
    Watch out for my adapters for these small thingies. It makes things so simple
    BTW: you can get V50 for $299 when on sale
    Car pc integration with ease
    Car mediacenter
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. modified xbox instead of a PC?
    By hydraulix in forum General MP3Car Discussion
    Last Post: 12-05-2005, 01:14 PM
  3. Pocket PC and Laptop GPS Software
    By faz211 in forum GPS
    Last Post: 09-18-2004, 04:56 PM
  4. Pocket Control PC! smartphone app
    By snmnetwork in forum Input Devices
    Last Post: 09-14-2004, 06:38 AM
  5. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 02:59 PM
