Results 1 to 10 of 19
Thread: Extending IDE cables?
    Das
    Das is offline
    Constant Bitrate Das's Avatar
    Aug 2004
    Texas
    I was planning on putting my mobo far away from where I want the CD-ROM drive. So my question was, has anyone or does anyone know how to extend an IDE cable about 6-10 feet? or would the delay be outrageous?
    Just brainstorming, thanks for anything you can come up with.
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    type extending ide cables in the search box
    Signature: [==||========] 20% complete
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    From what I've read, few people have had success success jusing such a long IDE cable, but IDE was never intended to be used over 18" (I think). Just do a search and you will see what people have done to achieve this. I think you would be better off just using a IDE -> USB converter and using that to connect your drive to your motherboard.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Variable Bitrate hevnsnt's Avatar
    Mar 2004
    I personally think Quattro-A4 is exactly right.
    www.i-hacked.com Hardware hacking articles
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I haven't answered this question (this week) so i can help.
    Basically your milage will varrey.
    Get 80 conductor
    2 connector (not 3, so you will only be able to connect 1 IDE drive to this cable)
    Make sure you have sufficiant power to the device (i had power issues with my setup, i guess i need to upgrade to the opus 150w if i want the fan controller and 12" UV cold cathode)
    http://www.stonewallcable.com/produc...++++++++++++++ is the url
    They are pretty expensive but prompt and you don't have to do it your self.
    My extended IDE cable is 72" or 6 feet. I could shorten it to about 4.5-5 though if i needed to.
    Don't even think about running a hard disk on it (although some have) only CD/DVD drives.
    If you have trouble make sure you are getting sufficiant power and that all of the cables are tightly seated. CHange the bios settings to a slower transfer rate if you must for troubleshooting.
    Some people created their own cable 15' with Cat5 cable. Their doesn't appear to be any lag. It takes my drive about 5 seconds to recognize the CD, load the track info and start playing.
    Oh, and Learn to use the Search funtion or every thread you post you will get people saying SEARCH.
    Jan 2004
    California
    I have had some problems with my IDE --> USB convertors. But in retrospect I could have been experiencing the power problem that i was having. I should test that out to see if the USB converter still works
    Dec 2003
    New York
    You can get the usb converter for a cheaper price than the IDE cables. If I were you I would go with the converter.
    Installed
    Jan 2004
    California
    Depending on how many feet. Mine was about equal. If I had to do it all over again i would say SCREW USB and go firewire. Firewire is much more suitable for streaming than USB 2. The 480 mb per second is bursts and is unsustainable while the firewire offers sustainable rates near USB 2. Also you will probably have many many more USB devices than firewire utilizing your USB bandwidth.
    So either go extended IDE or get a firewire bridge.
    Dec 2003
    New York
    Have to agree with you on the firewire, it probably woud be the best solution.
    Installed
    Jan 2004
    California
    Quote Originally Posted by Quattro-A4
    Athough the extended IDE cable will work. If power is a concern then you don't want another power hungry mouth to feed (USB or FireWire to IDE converters need power) then IDE is the way to go. I can vouch for 6 feet of IDE and others can vouch for 15' +.
    BTW
    Do you see dead puppies too?
  1. Custom Length Round IDE Cables
    By antimatter in forum General Hardware Discussion
    Last Post: 08-17-2004, 01:23 PM
  2. extending IDE cables
    By acura cl in forum General Hardware Discussion
    Last Post: 06-02-2004, 03:07 PM
  3. thin flex IDE cables
    By [H]Bugster in forum General Hardware Discussion
    Last Post: 04-01-2004, 02:28 PM
  4. Extending IDE cables?
    By JeremyD in forum General MP3Car Discussion
    Last Post: 06-27-2003, 02:32 AM
  5. Long IDE cables
    By dan0myte in forum General Hardware Discussion
    Last Post: 03-16-2001, 06:37 PM
