Extra Fans, power???
I found som old fans in power supply,s I cut up there cables and hooked em up to a battery. It wouldnt work. If I could fins away to power the power supply fans through an external battery, It would turn out great.
Any ideas?
What battery did you hook them up to? They should be standard 12V fans. If you hooked them up to a 9V they may not spin
Well,
hehe I hooked em up to two 6V battery's, the BIG battries that are as big as like a coke can. I got those from the ACE. Hmm.. 12v battery's
thanx
Well if you have two six's then you can hook them up in series to get them top make 12 volts
Hmm.. Still didnt work.
I am gonna get a DC-DC convertor from Scot Kinacid, I will ask him to put multiple power supply fans
I am gonna get a DC-DC convertor from Scot Kinacid, I will ask him to put multiple power supply fan ports so that I can have more than one fan going at the same time..
I am gonna have one pulling air into the system and a Fan Slot<A HREF=http://www.3dcool.com> U can find em here</A>, two pushing air out. so it will be Cool. Thanx.
Will a rechargable battery off a R/C car work?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
