Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Need to find a switch, 4 way 'joystick'
  1. #11
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    please tell us how you plan to use this.
    It's the cake having/eating thing.
  2. #12
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    I don't know ho big you need it but.
    DigiKey #P12330SCTND $4.48
    DigiKey #401-1130-1-ND $1.43
    You would still need to fabricate the actual button to use with it, but there you go.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  3. #13
    Mar 2004
    CT
    yeah, i found that 8 way, i only need 4 though, i could not wire the other 4, but then i'd end up missing half the time.
    401-1130-1-ND from digikey is what i was looking for
    I also found http://www.mouser.com/index.cfm?hand..._pcodeid=68801 from mouser.
    As for the button to put over that i'm not sure, i was hoping to find something with a long stem that had it's own 'natural' button... but maybee i can snag a dead cell phone and steal the button from that.
    As to how i plan on using it: My OSD has the following 5 functions: menu, Select, Up,Down, and Power. Instead of drilling holes for 5 buttons, i decided to just drill 2 buttons. 1 Power, and 1 for the 4way: on the 4 way, i'd have up as up, and down as down, then left and right both as menu, and the center push as select.
  4. #14
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    Hmm.. the first thing I think of is the little mini-joystick on the fighter-style joysticks. It looks like a mittle mushroom cap (about half-inch round) it's just got four directions, and I think you can push them too. I know trhe Logitech joysticks (at least mine) has it, I'm not sure who else makes them with it.
    I'm not sure how easy it would be to dissect it, but it might be worth trying if you can't find anything else that will work for you.
    Good luck,
    Kris
    How Much Horsepower Can I have And Still Go To Heaven?
  5. #15
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Quote Originally Posted by Superduck
    It's called a hat switch, some are 4-way and some are 8-way, but I've not yet seen one that has center push functionality.
  6. #16
    Oct 2004
    Why not rig up a normal 4 way switch with either left or right as select? it'd take some getting used too, but it would work.
  7. #17
    Mar 2004
    CT
    actually i think i found what I'm looking for finally in mouser and digikey thanks to the part numbers provided earlier
  8. #18
    Constant Bitrate e_z_street's Avatar
    Feb 2004
    I think this is exactly what you are looking for from E-Switch:
    http://www.e-switch.com/series/JS1100.html
    Chris Electronics Distributor (800-356-6599) has 1200 of them and they sell for about $3.50 for single part purchase.
    http://www.chriselectronics.com/inventory.cfm
    part number: JS1100AQ W360000
  9. #19
    Mar 2004
    CT
    that looks like it would work too, thanks.
  1. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 06:06 PM
  2. Switch letting power through
    By veetid in forum Power Supplies
    Last Post: 06-08-2004, 01:09 AM
  3. Looking for a specific switch - HALP.
    By Gutter in forum Off Topic
    Last Post: 04-15-2004, 12:46 PM
  4. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 04:59 PM
  5. Power switch to the opus
    By XMen in forum Power Supplies
    Last Post: 02-04-2004, 02:22 PM
