Hello,
I've got a epia-v 800mhz mb (with a one ide and one floppy connector), so i'm forced to put both the harddrive and the dvd on the same cable. Unfortunately my 2.5 hd (ibm travelstar) and slim dvd player (tried a toshiba and one from my gateway, i believe it's a hitachi) won't play nice together:
When the toshiba dvd and hd are together, the toshiba shows up as a slave but the hd disappears.
When the hitachi dvd player and hd are together, the hitachi shows up as the master, and the hd is nowhere to be seen.
By itself the hd (with no jumpers set) shows up just fine, same with the dvd players. The hd has provisions to be jumped as a device 0 (default, no jumper), device 1, or cable select. I've tried it with device 1, but not yet with cable select.
I've been able to successfully use a 3.5" hd, set as master, in place of the little travelstar, and the travelstar still works in my
laptop, so i don't think it's a bad hd.
Anyways, my question is, what ARE the slim dvd players by default (as far as factory setting to salve, master, cs, etc.)? Do most laptops just have two ide channels to avoid this situation?
Thanks for any help you can give. I've tried a few different ide adapters, in case the ones i had were bad.
