Results 1 to 10 of 11
Thread: batteries in series ?
    Whistle Tip pimpJ's Avatar
    Metro, TX
    I'm willing to google this myself, but I don't have the keywords to search with.
    I've heard about batteries in series/ batteries in parrallel, I wanted to find out more information about it, but I can't seem to get any comprehensive google hits.
    any help ?
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
    Variable Bitrate Dracos's Avatar
    United Kingdom
    Ive JUST done a lot of research on this. Series means youre gonna end up with 12x the number of batteries on voltage and overload your system. 2 batts x 12v = 24v output.
    check my post in power supplies about cranking issue solved for more info.
    Oct 2004
    www.doomportables.org has some stuff in their consoles section.
    Metro, TX
    aight, thanx
    www.neoterikos.com
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    Series is kinda like Dracos said, but not.
    When wiring in series (load to bat1+, bat1- to bat2+, bat2- to load), you add the voltages of the batteries together. So two 12v in series does get you 24v, but you can also wire two 6v in series to get 12v. Like in a flashlight, where you put two batteries in front-to-back, the light is 3v, as each battery (size AAA to D) is 1.5V.
    When wiring in parallel (load to bat1+&-, bat1+ to bat2+, bat1- to bat2-) you retain the same voltage, but basically just double your reserve capacity. So two 12v in parallel is like one big 12v.
    And just to make it fun, I'll throw this one in, although I don't know what the procedure is called: You can take four 6v batteries, wire them together in pairs in series (12v), then wire the two groups of two together in parallel (bigger 12v).
    Generally, in a car, you don't need series wiring, since the batteries are 12v. But if you need to get creative with battery placement, you could get two 6v batteries (which are smaller), place them where appropriate, and wire them in series.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
    Metro, TX
    what's the advantage ?
    for me personally, the reason I'm considering it is because my stereo's too much for my alternator at times. Would the multiple batteries really benifit me unless I got a new alternator ?
    www.neoterikos.com
    United Kingdom
    so many time i see this same thing. Batteries dont power your car when its on. The battery merely gives you crankign power and holds the presets for your stereo. the Alternator is the powerhouse of your car. THEREFORE - upgrade your alt and your problem is solved. no need for all this battery fiddling.
    May 2004
    Alameda, CA
    How is your stereo "too much" for your alternator? Do you have a lot of subs/amps or something (over 2000W)? You may just need capacitors, not blow a bunch of $$$ on a new alternator. If it were really "too much", it would burn out the alternator.
    The advantage of multiple batteries is extended battery capacity. I can run my computer and sound system (about 1000W) at near full volume for about 3 hours without the engine running off of two Yellow Tops. I could watch movies off the computer with the sound just playing off the front two speakers for like 6 hours or more. And of course the simple-but-useful fact that I can just leave my vanputer on when I'm away from my vehicle for hours on end, very useful for trips and errands, and those long USB1.1 file transfers.
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by Dracos
    Yep, the only advantage to have an extra battery is when you are powering things when the car isn't running.
    It's the cake having/eating thing.
    Jul 2004
    yorkshire england
    not ENTIRELY true chaps, if you connect something DIRECTLY to the battery while the car running ( depending on how much power you are drawing) it is possible to take power off the battery
    ie: if alt will supply for argument 10 amps ( i know this wouldnt occur) and you draw 20 amps you will actually draw power out of the battery assuming the alt dont blow up
    if you are really fussed about what is happening to the battery you COULD put a second one in the car with a switch that will swap between the two ( so you only charge one at once but you do have the possibility of using two) if you get me
    amd k6-2 450
    64 meg ram
    5 gig hdd
    all in an old bit of metal
    all for under 20
    and now a 500watt inverter for 20
    thats 40 in total
    not too bad for a noob
  1. Two batteries in my ride
    By SAScooby in forum Power Supplies
    Last Post: 10-28-2009, 02:23 AM
  2. Matrix Orbital MX Series
    By Rob in forum LCD/Display
    Last Post: 09-01-2003, 05:13 PM
  3. FS:HYPERION Simplicity Series standalone Controller and inverter
    By kickercivic1 in forum Classified Archive
    Last Post: 06-25-2003, 10:01 AM
  4. Questions on batteries
    By Sir_Pyro in forum Power Supplies
    Last Post: 03-25-2003, 09:34 AM
  5. Powering LCD panel with batteries
    By paulw in forum General Hardware Discussion
    Last Post: 11-01-1999, 02:37 PM
