Does it start working again if you shut of the screen, or the PC?
Sometimes when I use my remote starter to start my truck I will enter my truck and my Lilli will have power but will say "no signal input". I can hear my PC running though. If I cut power w/ my switch and then turn it right back on everything is OK. This only happens when I remote start and it doesn't happen all the time.
Any ideas??
Current Vehicle: 2007 Dodge Nitro
Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
When I remote start my truck...if I wait the 10 minutes (Opus shut down time) I have to restart it.Originally Posted by tbird2340
Edit: Never mind, you said you could hear the pc running.
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
Yea, it will work when I shut down the PC and turn it back on.
Sounds like the pc is going into standby?Originally Posted by tbird2340
What's the time period between when u start it and then get in the truck?
Is the pc set to hybernate or standby?
It's set to hibernate. I don't have an OPUS so I can't use stand by. I tried pushing the space bar on the keyboard but that don't work. I don't recal how long it is usually before I get in my truck but I wouldn't say more then 5-10 minutes.
Set it NOT to hybernate, then see if it still has the same problem.
How do you have your opus wired? It sounds like your accessory line becomes hot when you remote start the car, but soon after that, since the key is not actually in, its probably not staying live and so the opus is shutting down. Hook a voltmeter up and see what happens to your voltages when you remote start.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
I don't have an OPUS. I have an ITPS + PW70a
I have a remote start, and I have a problem sometimes too. My acc line goes hot a lot longer than if I were to start it myself BEFORE it starts to crank. It usually resets my computer. Maybe that's what's happening to you?
