Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
Thread: PC performance
  1. #11
    Whistle Tip pimpJ's Avatar
    Metro, TX
    Quote Originally Posted by WeeZyFellA
    it can make all the difference, u should upgrade your hd or just delete unwanted programs and file that you dont use.. i have a 120gb harddrive and only have 20 gibs left, but when it was new it was alot faster then now,
    interesting, I'll do that
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
  2. #12
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by pimpJ
    I'm good on spyware, no probs there
    I didn't trust the ctrl-alt-dlt data.. I don't know why..
    It was saying like 15-20%, in which case it's def. the RAM. I assumed that was wrong.. maybe not
    Trust it. It is your RAM. That or an overly fragmented hard drive. But it is your RAM.
    And yes I meant at least 256MB more.
    Installed.
    -GPSSecure- - GPS Tracking
  3. #13
    Variable Bitrate WeeZyFellA's Avatar
    Oct 2004
    New York
    i also add another 512mb kingston ram, so i have 1024mb
    that helped speed up the programs when i was multi-tasking, especially when workin with photoshop and the internet at the same time
    if anything upgrade your ram and delete the garabe off your hd
  4. #14
    Jun 2004
    Savannah, GA
    HD is 55 gb, 49 used. I've been considering updating.. there's also a ton I could delete. would that make a diff. at this point ?
    Also have you defraged lately?
    My Computer> Right Click C:> Properties> Tools> Defrag
    Run it right before you go to bed and leave your computer on
    Kefka_Killer.owns(you);
  5. #15
    USA
    I get it. If I up it I'll probly just get a gig
    as long as we're on the topic. dual channel 1024 mb vs. 2 seperate 512 mb sticks ? any universal advantages ? or is it on a system to system basis ?
    Mmmm dual channel 1024MB. I hope you have a lot of money.
    Installed.
  6. #16
    Metro, TX
    Quote Originally Posted by kefka_killer
    yah I've been meaning to do that lately.
    I saw a file that "file on disk" was like "file size" x 2.. so that would be causing a problem...
    I'll do that tonight, then reevaluate if I need some more ram.. any responses to post #9 ?
    edit: oh.. dual channel = $$ ??
    www.neoterikos.com
  7. #17
    Constant Bitrate blackpacu's Avatar
    Jul 2004
    Setauket
    I know you said you checked for spyware, but check again adaware and spybot work the best for me.
    Is this just a problem when your burning cd's? It may be the program that your using. I know when i use nero to burn dvd's it will cause lag when changing windows, however, this is only when going to and from nero
    What other programs do you have running in the background when you noticed this? You could have something there that isnt playing nicely.
    You should also check out this site
    http://www.blackviper.com/
    go to the windows version that you have and look at the super tweaks
    Also it is a good idea to look at the service configuation page and disable any services that you dont need.
    Finally, have you updated all your drivers? Have you appllied any relevant patches for the software that you use? You can usually get these files from the vendors site etc.
    let us know how you make out
    amd 1700, biostar m7ncg 400, hitachi deskstar 120 8mb , 512 pc2700, liliput 7"
    now to put it all together
  8. #18
    USA
    All 1GB sticks cost a ton! Also depends on what speed you get.
    Installed.
  9. #19
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    since you already have 512, just get another stick of 512 for a total of 1gb.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  10. #20
    Metro, TX
    Quote Originally Posted by brady
    shux..
    2 512's it is..
    www.neoterikos.com
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 05:27 PM
  2. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 10:48 PM
  3. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 05:30 AM
  4. Do ISA Cards lower the performance of a PC ?
    By felix99 in forum General Hardware Discussion
    Last Post: 11-05-2002, 04:37 PM
