yikes
an average stick for 512mb cost around $60-180 depending on the company and speed
a pc3200 from kingston or CORSAIR MICRO cost around $90 as for a 1gb stick it would cost u more then $300
yikes
I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
www.neoterikos.com
just saw the other post damn i a slow responder,
defrag you drive is a good idea, getting the ram is still a good idea, there is quite a difference between 512 and 768 that you will notice. I would still go and disable any thing that you dont need from running though
As far as the dual channel goes, it'll be faster then single channel, but if you dont have a sitck of 512 in there now its going to be the more expensive route, generally you want to use matched pairs for dual channel ram,
amd 1700, biostar m7ncg 400, hitachi deskstar 120 8mb , 512 pc2700, liliput 7"
now to put it all together
its amazing to me all the crap that somehow manages to find its way onto my computer..
I don't think I've ever played some of the 1+ gb games I have on here
www.neoterikos.com
I realize this is a total noob question.. but..
I've got 2 "pairs" of ram slots. as in 2 right next to eachother, then a space, then 2 more.. does this mean I could have 4 x 256 ? right now I have 1 256 stick and one empty slot in either pair. could I just buy 2 more 256 sticks (obviously the right type and speed) and stick those in there ?
www.neoterikos.com
more than likely. check your motherboard documentation but i dont see why not.Originally Posted by pimpJ
VIA EPIA 533 MHz
256 MB RAM
7" Lilliput VGA Touchscreen
20 gig HD
Media Engine 2.1.4
GPS - Earthmate/SA2004
802.11b Connectivity
pimp. that should be easyOriginally Posted by Nav_Attack
www.neoterikos.com
why would u go with 2x256 sticks, when u would want to update later on it the two sticks would be no good....just get 1 more 512 stick, it will cost lesser to get 1 512 rather then 2x256
run some spyware programs and also check for adware as welll,
spybot search & destroy along with Ad-Aware SE Professional, is a must do after or before u defrag your computer
just keeping in mind that to further upgrade would involve you taking out one or more of those sticks.
VIA EPIA 533 MHz
256 MB RAM
20 gig HD
Media Engine 2.1.4
my only motivation for that was that I was under the impression that the 2 pairs of RAM slots had to be even. As in, I couldn't have 768mb in one and 256 in the other ? is that not true ?
www.neoterikos.com
