Results 1 to 7 of 7
Thread: Need help taking a device apart
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    Hello everybody,
    I need your help disassembling a device I have.
    I opened it up yesterday and all of boards are glued (Epoxy?) to the case and I can't just pull them out. What would be the best way to undo those glue thing?
    Do I cut using Dremel? or should I heat up with something?
    Also, I don't want to mess up the case either.
    Any suggetions?
    Jun 2004
    Central California
    Heating will probably cause damage to the case. Is the glue stuff soft enough to cut with a hobby knife (eg: x-acto knife)?
    Nov 2003
    TN
    Quote Originally Posted by edikp
    That stuff is hard. I haven't done anything yet, but if I were to cut with a knife, it could take long time.
    If I use Dremel, could dust from this stuff cause any harm to the board?
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    should be fine. Point a fan at you while you grind to blow particles off the componenets, nothing looks open other than that speaker
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Nov 2003
    TN
    Quote Originally Posted by EBFoxbat
    Thanks guys.
    I guess it's Dremel time!
    Raw Wave
    Jun 2003
    If Im right :
    By looking at it, the glue look like it came from a hot glue gun, they are kinds rubbery. It cant be epoxy cause I can see the "thread" from the glue.
    I have removed them by using a soldering iron to melt the glue while I lift the board from the case. Dremel it if you feel more confident that way.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    A heated knife might work well too.
  1. lilliput won't work - USB device not recognized...
    By aegray in forum Input Devices
    Last Post: 06-16-2009, 03:38 PM
  2. Replies: 12
    Last Post: 09-23-2004, 03:00 PM
  3. Overheating safety device
    By NiN^_^NiN in forum General Hardware Discussion
    Last Post: 09-18-2004, 01:03 AM
  4. What GPS device should i get ?
    By eazyrog in forum GPS
    Last Post: 04-29-2004, 12:14 PM
  5. My idea for an input device ....
    By foneman in forum Input Devices
    Last Post: 09-22-2003, 09:03 PM
