Results 1 to 9 of 9
Thread: Why is my xenarc working without a ground?
    Illinois
    Ok, i wanted to hook the xenarc up straight to my opus. So i cut the cigarette adapter and realized it only had 1 wire...so i hooked it to the yellow wire of my Y adapter coming from the opus and my tv powered on...
    I also tried my AC adapter for the xnearc. The AC has 2 seperate wires...a ground and a power. I know the ground cause it touched it to a power wire and it sparked. Anyway, i hooked the power wire to the yellow wire of the opus again and the xenarc powered up..
    Am I missing something?
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    It is grounding through the vga cable. Very bad. I wouldn't do that too much. It will ruin either a mobo component or something in the monitor.
    ATVMS.com
    Aug 2003
    Michigan
    sfay's right. ground your xenarc.. um, now.
    VIA EPIA 533 MHz
    256 MB RAM
    7" Lilliput VGA Touchscreen
    20 gig HD
    Media Engine 2.1.4
    GPS - Earthmate/SA2004
    802.11b Connectivity
    Jun 2004
    Savannah, GA
    Actually if you look at the cross section of the power wire on the very outside there is the black insulation inside of which is the hot(white in my cable) wire. But around the hot wire is some stranded wire which is the ground. Also if you open up the actual cig adapter you can see that the ground is connected to this stranded wire.
    { ( [0] ) }
    {} = Black Insulation
    () = Ground wire strands
    [] = Hot Wire insulation
    0 = Hot wire
    I would seriously recomend redoing your power wire. If you follow my diagram you'll see that if you've cut away your outer black insulation then your ground wire is loose and you don't want it shorting out.
    I hope all this makes sense
    Kefka_Killer.owns(you);
    Illinois
    ok so to make it easier, could i just use my AC adapter that already has the 2 wires separated.?
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Quote Originally Posted by nappyjim
    Wires are wires, it dosent matter if you have AC or DC current. But, for future reference, AC's ground is the third prong.
    Quick! To the Popemobile!
    In a barn
    Quote Originally Posted by BiohazrD
    and kinda the right one.... in a way.... kinda..
    When in doubt, moo at things.
    Rochester, NY
    Why are you hacking up good equipment? Go to Radio Shack and buy a DC Power Plug, $2.59 for 2 of them. Just make sure you solder the tip correctly (tip is + on xenarc).
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    what he means is using the other end of the plug where the 2 wires will come out of the screen.
    and while this is technically correct i think you are are very confused, the ground on the ac power in your home serves a very different purpose to the "ground" in your car
    Signature: [==||========] 20% complete
  1. Xenarc TSV Touch Screen not working (FIXED!!!!)
    By digitallexus in forum LCD/Display
    Last Post: 12-07-2009, 01:32 PM
  2. Replies: 88
    Last Post: 09-15-2004, 05:38 PM
  3. Xenarc Touchscreen not working
    By Sunglassesron in forum LCD/Display
    Last Post: 09-06-2004, 05:20 AM
  4. Xenarc Touch Not Working
    By MSUC5Vette in forum LCD/Display
    Last Post: 08-18-2004, 11:42 AM
  5. first screenie JCP-ALPHA working on xenarc
    By BOND007BE in forum Software & Software Development
    Last Post: 11-05-2003, 06:46 AM
