Results 1 to 4 of 4
Thread: shutdown?
    Newbie murdaki11's Avatar
    Oct 2004
    Sacramento CA
    shutdown?
    This may sound very stupid to some of you. How does the shutdown controller work in the Opus power supply. What i dont understand and couldnt really find anything about when I searched. Is what happens when i turn the car off, turn the car on ect. Run in to the store for like 2 minuets ect?
    Jul 2004
    The Opus is connected to the battery for main power, to a 12v+ ACC/IGN for sensing ingnition and a ground. When you start your car, it senses the ACC/IGN and it sends a signal to the computer to boot up or come out of hibernation/standby just like you were pressing the PWR button. It boots up and runs. When you turn the car off it will no longer sense the ACC/IGN and send a signal to the computer to shut down/hibernate/standby. It's pretty slick. Go to opussolutions.com and read up on it and do a search here. There's tons of info on this subject. Hope this helps you out some.
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I don't understand your question.
    There are different jumper settings on the Opus 90W. I've got mine set at 10 minutes. When the ignition (blue) stops seing juice for 10 minutes it shuts down. If within the 10 miunutes I get back in the car, the unit stays on.
    Does this answer your question?
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Oct 2004
    Sacramento CA
    Yes, thank you very much guys
  1. New Improved ATX Shutdown Unit!
    By Danceheaven in forum General Hardware Discussion
    Last Post: 04-15-2004, 09:52 PM
  2. Keyless Entry Shutdown Controller
    By Sinorm in forum Power Supplies
    Last Post: 04-07-2004, 08:30 PM
  3. Can you adjust shutdown voltage on Opus 150w?
    By Visual Echo in forum Power Supplies
    Last Post: 03-26-2004, 08:04 AM
  4. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 01:33 PM
  5. startup shutdown etc.
    By marsjell in forum Power Supplies
    Last Post: 06-19-2002, 06:07 PM
