Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 81
Thread: this install is kickin my ***....i really need help
  1. #21
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by nappyjim
    Just to veify, what is power and ground with those 2? And also, are there any certain pins on my mobo i need to have it hooked to. I was assuming pins 3-4
    Yeah, the 2 pins we figured out earlier that you had to jumper to turn it on. I believe they are actually pins 5 and 7, but we were calling them pins 3 and 4 for easier reference.
    Tidder
    Try RevFE
  2. #22
    Illinois
    Quote Originally Posted by Tidder
    Just for testing purposes yeah.
    If you don't know, your remote also puts out +12v, it's just switched instead of constant.
    ohhhhh TRUST ME, i know. Ive used my damn voltmeter more times in the past 2 weeks than i have my entire 21 years on this blasted earth!! BLAST MICROCHIPS, MICROROCESSORS, MICRO RC CARS, ANYTHING MICRO......TO HELL!!!!
  3. #23
    Sep 2003
    New Mexico, USA
    pins 3-4 correct in first row, correct?
    That's right.
    Tidder
    Try RevFE
  4. #24
    Jan 2004
    Even though the remote turn on wire from the stereo is giving 12volts it may not be able to handle enough amperage (current) to turn on the OPUS--it's made for a low power stereo amp turn on circuit.
  5. #25
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    Have you tried using larger wire? If you use to small a wire (20 gauge) it will not be able to draw enough current.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
  6. #26
    Sep 2003
    New Mexico, USA
    The problem with this idea guys is that his Opus is staying on. The opus doesn't flicker does it?? If you sit there and plug and unplug the remote wire over and over, what will the opus do? Are we looking in the wrong place?
    Tidder
    Try RevFE
  7. #27
    Illinois
    i dont know. I will have to test this tomorrow.
    But i was reading over the opus manual and it says that green/white pin should be pluged into pins 8-6. both of these are shown to be in the second row.
  8. #28
    Sep 2003
    New Mexico, USA
    On your motherboard??
    No man, we already figured out the pins on your motherboard. It wouldn't have powered up if we were using the wrong pins. Don't go crazy, stick with what you know.
    Tidder
    Try RevFE
  9. #29
    Illinois
    Quote Originally Posted by Naamanf
    no, im using larger wire now. Im saying when i was using 20awg wire to run my pc with my itps and 70w power supply, the damn thing actually worked. Even with a 3.5hd needing power.
  10. #30
    Illinois
    well then why in the hell was the mobo able to power up when I didnt even have the green/white wire hooked up to it. lol
    go to page 7. look at the diagram.
    http://www.mp3car.com/products/DCX3_...User_Guide.pdf
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 10:21 AM
  2. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 03:37 PM
  3. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 03:03 PM
  4. Lilliput 619GL-70NP Touchkit XP Home Install
    By Windchsr in forum LCD/Display
    Last Post: 04-25-2004, 07:23 AM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 08:10 AM
