Page 6 of 9 FirstFirst 123456789 LastLast
Results 51 to 60 of 81
Thread: this install is kickin my ***....i really need help
  1. #51
    Jan 2004
    St. Louis
    Ok, I read through this whole thread but am still a little confused...
    When you have it plugged inside your house, do you ALSO have the USB touchscreen plugged in as well?
    When you have it plugged into your car, have you powered up with everything BUT the USB touchscreen?
    I'm just asking (if not reasking ) because the OS can have issues with either USB devices if the ACPI (power settings) are not reading peripherals correct.
    Lastly...what does your Event Logs say under "System" when you're running inside the house. I would also disable "Automatic Reboot" on system failure just incase you are getting a BSOD, you may see some critical information on either a faulty driver or ACPI problem.
  2. #52
    Illinois
    Quote Originally Posted by tipastar
    OK, right now. I have my house power supply (AC) hooked up to the computer outside. I have my fullscreen desktop monitor hooked up to the computer also.
    Then I swtich the AC power to my OPUS 150w DC-DC.
    The ONLY differnece i notice is with the AC is seems the computer will reboot itself one time and the second boot windows will load.
    With the DC it seems like the windows success rate is 1 in every 5 boots windows will load.
    And even when windows does load on either AC or DC power, it will then reboot itself at various timing intervals for no reason whatsoever.
    So right now, the only peripeheral plugged into the computer is my keyboard (not usb) and fullscreen monitor(not usb)
    How do i view my events log? And do you mean disable auto reboot thru my BIOS right?
  3. #53
    Illinois
    ok, now im going thru my DC and windows has booted up 3 out of 3 times.. BUT now when in windows, it is rebooting again for no reason. All 3 times I let windows load, i then load frodo player and about 20 seconds later, windows reboots.
    im gonna try loading something else.
  4. #54
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    what is your cars battery voltage - engine off and engine on and if the engine is on and you try start the pc what happens then ?
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
  5. #55
    Jan 2004
    St. Louis
    For event logs, Right click the "My Computer" icon and select "Manage". From there, expand the "Event Viewer" sub tree and you'll see "Application" and "System".
    This all is good and dandy though...if and when you get a successfull boot either in Safe Mode or Normal.
    To disable the auto reboot, Right click the My Computer icon and go to "Properties". From their, click on the "Advanced" tab and on the bottom you will see "Settings" in the Startup and Recovery section. Click the "Settings" and remove the checkmark for "Automatically restart" under the System failure section of this screen.
  6. #56
    Low Bitrate megamind's Avatar
    Aug 2004
    Netherlands, Rotterdam
    Did you try a big capacitator?
    05155'30"N 0434'31"E
  7. #57
    Illinois
    I CANT be my power soruces. Cause this is happening BOTH on DC and AC current.
    Im thinking its something with the MOBO.
  8. #58
    Mar 2004
    Vancouver, BC, Canada
    Quote Originally Posted by nappyjim
    well for god damn 200 bux i sure hope im not overloading the opus!!!
    I got a v10000 mobo. 3.5hd 200gig. Thats all. NO cdrom or anything.
    Then i have my xenarc 700tsv hardwired to opus also.
    I will be doing all your suggestions today and let you guys know what happens.
    I have just about the same setup and I don't have any power problems.
    My guess is it is a defective OPUS, or a bad connection from the remote turn on wire, or to the power switch on the motherboard. Could always be a bad Windows install too.
  9. #59
    Illinois
    well for some unknown reason, it is booting fine now.
    I took the car out and windows still shut down one time and rebooted for no reason. But 1 time in 30 minutes isnt bad i guess.
    But windows wont come back from hibernation. It will try to resume and then i get an error and i have to restart normally.
    But i find that it seems restarting is actually faster than coming outta hibernation.
  10. #60
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Maybe you should exchange your Opus and get a new motherboard. That way you can pretty much rule out both as the cause.
    Tidder
    Try RevFE
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 11:21 AM
  2. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  3. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  4. Lilliput 619GL-70NP Touchkit XP Home Install
    By Windchsr in forum LCD/Display
    Last Post: 04-25-2004, 08:23 AM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
