Page 1 of 9 123456789 LastLast
Results 1 to 10 of 81
Thread: this install is kickin my ***....i really need help
    Illinois
    My GOD! 2 weeks into the install and I have gotten basically nowhere except for running about 40 feet of wires from the front to the back of my car which I am now gonna prolly tear out anyway.
    Heres my problem. The PC will boot up and windows will start to load, the XP logo will come up with the progress bar under it. Sometimes it will get thru all the loading and explorer shell is about to popup and then BAM!!! the via logo comes back up and it starts all over again.
    Sometimes the XP logo will just pop up for a second and then the computer will restart itself.
    Or sometimes XP will load. And then when im in xp, sooner or later, usually sooner, it just reboots for no reason.
    Can someone throw me a freakin bone and tell me what the hell im doing wrong.
    BTW, this ONLY happens when im hooked up in the car. When i bring the pc inside and hook up to an AC power source, it runs fine.
    For my PS in the car i got an opus 150. I am running a dedicated 8awg power wire from the battery straight to the OPUS and I soldered the 8awg power wire to the opus power wire. I have a 8awg ground less than 2 feet of wire also soldered to the opus. And then i have the remote wire that turns my radio on hooked up to the opus also.
    Now the thing is, when windows restarts, the actual OPUS never loses power. And neither does the MOBO. The fan will keep spinning as normal, but the reboot process will just start all over. In BIOS i am able to check the voltage level and everything seems fine.
    12volts - 12.46
    2.5 volts - 2.4
    5 volts - 4.89
    These are almost the exact same values I get when hooked up to an AC power source in my house and in my house the computer runs fine.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Strange...
    If it works fine inside, I would point the finger at your power supply.
    Do you plug all your peripherials that you have in your car into your computer when you go inside? What all do you have plugged into your opus?
    Tidder
    Try RevFE
    Illinois
    into my opus i just have the monitor also hooked to it.. thats all.
    When i go inside yah, everything gets plugged in.
    Really all I have plugged into the car right now is the keyboard, monitor usb(touchscreen) and the sound plug.
    Sep 2003
    New Mexico, USA
    Well, what all you got? 3.5" hard drive? Desktop or laptop cd-rom? GPS?
    Tidder
    Try RevFE
    Illinois
    Quote Originally Posted by Tidder
    3.5hd yah. But same thing happens when I plug in the 2.5 slim HD i also have. no cdrom. All thats in the PC case is the mobo, 2 sticks of ram and the HD
    Illinois
    Does it matter if I run all my wires down the same path? I mean i know this will affect noise in my speakers, but as far as having the PC actually run smoothly, it shoulden have an affect right?
    Sep 2003
    New Mexico, USA
    Shouldn't.
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    what do you have your ground hooked to?
    Tidder
    Try RevFE
    Illinois
    the kicker is, before i had the opus, i just had a power supply and itps and the power, ground, and constant all ran off of 20awg wires in my cdplayer and the computer actually ran then.
    Illinois
    Ground is going to a piece of metal in my trunk.
    well, its grounded to a peice of my car frame
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 11:21 AM
  2. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  3. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  4. Lilliput 619GL-70NP Touchkit XP Home Install
    By Windchsr in forum LCD/Display
    Last Post: 04-25-2004, 08:23 AM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
