Results 1 to 10 of 18
Thread: Ding Dong my hard drive is gone :(
    Super Moderator xBrady's Avatar
    USA
    So yesterday I spent a few hours cutting a larger hole in my subwoofers box because my 10 inch died and I bought a 12 inch Kenwood. Got everything installed and working. Drove to work and on the way I was testing out my sub (make sure it was giving me enough thump ) and my carputer reset. I let it boot back up and as soon as windows booted it reset again. This time I got a disk read error. I brought it in today and ran like 20 differant diagnostic programs and tried to repair it. No luck. I finally decided to just try and format it. That worked and I loaded my music library back on. I put the hard drive back into my carputer and tried loading windows on it. It is able to copy all the files over but it won't boot off the drive (it just goes black). I tried this with several Windows CDs and either got the same results or worse.
    Sounds like it is time to get another hard drive unless any of you have further suggestions.
    Installed.
    -GPSSecure- - GPS Tracking
    May 2004
    what exactly did you run to try and fix it? you use any of the manufacturers utilities?
    might be time to invest in a laptop drive
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by rusty
    SNIP
    Whatever...
    Brady,
    What drive was it, Make/model/size?
    TruckinMP3
    Read the FAQ!
    USA
    I ran Norton Disk Doctor, the Seagate utitilities and some other programs off of Hirem's boot cd.
    It is a Seagate 120GB hd. 3.5"
    I was finally able to get Windows loaded on it. It is acting semi unstable... I am going to play with it a bit longer and hope all my problems go away
    Installed.
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    hahahahahah, i couldnt stop laughing when i saw the title, but yeah that sucks good to hear its kinda working tho
    Signature: [==||========] 20% complete
    May 2004
    Quote Originally Posted by TruckinMP3
    Whatever...
    lol - i use a desktop hdd as well... but if it goes then i think i'll probably buy a laptop hdd to replace it.
    the seagate utilitys are good - they've resuced a disk for me before which was looking dodgy.
    glad it's okay
    Low Bitrate megamind's Avatar
    Aug 2004
    Netherlands, Rotterdam
    So u put windows on the drive in another system then ur carpc? WindowsXP and 2000 uses ur hardware like motherboard and CPU to boot, if you place a harddrive with windows in another setup it will never boot (unless ur very lucky, or you have the same setup)
    05155'30"N 0434'31"E
    USA
    Quote Originally Posted by megamind
    No I didn't install Windows with differant hardware.
    Perhaps the Seagate utility did do something. It had found a bunch of bad sectors that it couldn't repair but I have yet to run into any problems for awhile. I have now reinstall everything and it is up and running. Restarted it a bunch and it doesn't freeze up the computer anymore.
    Installed.
    Jun 2002
    Colorado
    I have moved boot drives from one PC to another with diferent hardware (win2k) it worked just fine for me. It takes time the first boot, has to find all the new hardware... even MB level stuff like the IDE bus and PCI bridge.
    TruckinMP3
    Read the FAQ!
    Aug 2004
    hmm it never seemed to worked at my but it is possible ya..
    Maybe you should try a low level format.. You waranty will be voided probably but its worth the try..
  1. Did you know "single" Hard Drive Booted Faster?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-03-2004, 12:50 PM
  2. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 01:49 PM
  3. Laptop Hard Drive in carputer...
    By Powers in forum Newbie
    Last Post: 05-08-2004, 10:37 PM
  4. Laptop Hard Drive Problems
    By Powers in forum General Hardware Discussion
    Last Post: 04-28-2004, 07:21 PM
  5. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 12:24 PM
