Results 1 to 10 of 11
Thread: Harddisk Trouble??
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Question Harddisk Trouble??
    I have see many people have trouble with hard disk in there car.
    Im thinking about all the vibration from the sub. ?? What happen with the small plate in the hard disk with all the vibration..
    Try to put your hand on the hard disk when you play high, if you can feel some thing, you maybe have an explanation if your hard disk gone defect
    The solution is to hang up your hard disk in rubbing to get less vibration to your hard disk or use a 2 inch hard disk, it is build to handle more vibration.
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Do some research, This has been covered in detail.
    A serach on 'Hard drive mount'
    The short answer is do mount the drive firmly to a hard surface and use a desktop drive as they are less expensive.
    Also covered is the magnetic field from the magnets, the general consensus is do not worry about it either.
    TruckinMP3
    Read the FAQ!
    Low Bitrate megamind's Avatar
    Aug 2004
    Netherlands, Rotterdam
    Quote Originally Posted by 4u2n
    What would be the point of hanging them? The vibrations are still going trough it... Everyone always wants to hang theyr harddiks :P
    05155'30"N 0434'31"E
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I don't know. I do know this though, laptop drives are not built for vibration either.
    Tidder
    Try RevFE
    May 2004
    Denmark
    Quote Originally Posted by Tidder
    Maybe 2 inch disk not direct build to handle vibration, both it can handle more vibration than a 3 desktop hard disk
    Ditail at 4u2n.dk
    Here
    May 2004
    Denmark
    Quote Originally Posted by TruckinMP3
    Here is a link to get you started:
    http://www.mp3car.com/vbulletin/sear...earchid=497344
    The link not working
    Ditail at 4u2n.dk
    Here
    Jun 2002
    Colorado
    Fixed
    TruckinMP3
    Read the FAQ!
    Super Moderator xBrady's Avatar
    USA
    Hard disk trouble? I have never heard of anyone having hard disk trouble!
    Ding Dong my hard drive is gone :(
    Luckily it is working again
    Installed.
    -GPSSecure- - GPS Tracking
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    If my subs could make a one-g force on a 3.5 or a 2.5 drive i would be soo happy>
    Aug 2004
    Quote Originally Posted by lawrence
    A parked harddisk can stand up to 200G so
  1. Create an OBD Trouble Code?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-16-2005, 11:59 PM
  2. I'm in trouble..
    By Bravellir in forum LCD/Display
    Last Post: 07-15-2004, 06:51 PM
  3. Harddisk Noise
    By SportivoWISH in forum General Hardware Discussion
    Last Post: 03-26-2004, 10:29 AM
  4. trouble with playlists
    By kami333 in forum ME Archive
    Last Post: 01-21-2004, 06:49 PM
  5. Who knows some Winamp plug-in....which make new playlist from removal harddisk
    By Redeyed in forum Software & Software Development
    Last Post: 02-26-2001, 11:41 PM
