Results 1 to 8 of 8
Thread: Does EPIA M1000 use the 12v rail?
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    I'm sorry, I searched and didn't see any answers, so if someone knows off the top of their head let me know please.
    I'm prety sure it doesn't use it, but dunno.
    CarPC install is starting to come along again...
    May 2004
    Arkansas
    bumpity bump you guys don't want me sending 14.4v to my EPIA if it uses 12v rail do you? well thats what i'm doing! I have no 12v devices and i was told m1000's don't use 12v rail and its been working fine for a while, i'm just hoping it doesn't die a lot earlier than it is supposed to. and it wont if its not using the 12v rail. so someone tell me so i can sleep tonight
    Oct 2004
    Hey Gray. I hope you got your answer on this one by now. I am setting up almost the exact same system as yours. I thought the motherboard was on the 5V or 3.3V line, so if I used all 5V USB/internal devices I wouldn't be using the 12V line at all. and Voila! no car power fluctuation issues right? Wrong.
    I found this spec sheet on Via's Web site. Here's a snapshot of it. While measuring MP3 and application playback it measures a 12V load as part of the Watt consumption. So I it looks like the 12V line is always in use.
    Here's my link to the whole document: www.cs.uml.edu/~jhaas/carputer/epia_m.pdf
    The watt measurements begin on page 11.
    Here's a snapshot of one of the Watt measurement screens:
    Well, good luck and I hope you didn't fry your system.
    Jim
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Does that chart include components like HDs, which take 12V? No draw on 12V at idle would seem to suggest to me that the MB itself may not be using it.
    Only one way to really find out See if there's any current flowing through the power connector's 12V line during use. It'll require you to cut the wire, but that should be easily repaired.
    Oct 2004
    Actually, I guess that was a bad part of the screen to cut that pic off at. It kind of leaves the impression there's no watt consumption at idle. This isn't the case. Here's the top of the next page. You can see watts are being consumed at idle on the 12V line as well as the other lines. Oh well...
    May 2004
    Arkansas
    Well crap haha. I'm actually getting 12.8 or something volts because I used a couple of diodes to drop off the voltage coming in, and since I have a tank circuit it only goes down to like 11.7 volts. I think 12.8 is within tolerance, and am not going to worry about it . Seems to be fine!
    Aug 2004
    SE Michigan
    Yeah, a clean 12.8's probably fine. I'd be worried if you were running 14.4 like you initially state tho!
    May 2004
    Arkansas
    yeah that was before i checked my voltages and i forgot i had put some diodes in to drop that voltage down
  1. Question to all EPIA M1000 owners
    By bjorne_the_best in forum Power Supplies
    Last Post: 03-29-2004, 01:49 PM
  2. DC-DC Converter for C134 EPIA M1000 Nehmiah
    By entr0py in forum Power Supplies
    Last Post: 02-24-2004, 09:22 PM
  3. EPIA M1000 TV out black border problem.
    By Rudical in forum General Hardware Discussion
    Last Post: 01-19-2004, 04:34 PM
  4. Beware of look alikes- EPIA M1000
    By gizmomkr in forum General Hardware Discussion
    Last Post: 10-31-2003, 06:32 AM
  5. replaced MAX chips and still 12v on 5v rail
    By surfer6262 in forum Power Supplies
    Last Post: 07-15-2002, 12:51 PM
