Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: "Delaying" a 12 volt signal?
  1. #11
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Throttle back there gentleman. The RC network works for what I'm trying to do. Its all very informational, but I'm working with point to point soldering here. This most of this stuff would work for someone working on a car scale.
    Thank you for all of you help though. I'll keep all this stuff in mind.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  2. #12
    Quote Originally Posted by kiltjim
    (A huge length of wire won't work...so don't suggest it...)
    LOL. 186,000 miles per second. 10 second delay. 1,860,000 miles of wire. 13.49 for 35 feet is 39cents a foot. 1,860,000 miles is 9,820,800,000 feet. Thats a grand total of 3.8 billion dollars. The length would be long enough to go around the earth 77 times. Maybe they will give you a discount since you are buying in bulk.
  3. #13
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Quote Originally Posted by justICE
    You have quite a bit of time on your hands don't ya? lol
  4. #14
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    The 555 timer would work in one shot mode, but not for the size I'm working with.
    I didn't mean draw the current from the 555, obviously - couple it with a FET. But whichever.
    re: bajillion feet of wire delay 'circuit'
    You forgot to consider that the wire is going to need to be some horrendously negative gauge wire to prevent voltage drop over that distance. Going to cost much more than $3 billion
    In a parallel thought: they (always the mysterious 'they') are able to make exotic materials that slows light to a crawl. I wonder if the same is possible for electrons?
  5. #15
    Feb 2004
    PA, USA
    I work there. I would get a discount. But I don't think that much wire is gonna be able to surface mounted.
    Quote Originally Posted by mushin
    I read this about 3 months ago in one of my many physics magazines. They have managed to 'slow' light in essence. They (and in this case its not mysterious I think they were British) somehow worked with lasers of some strange wavelength, and managed to make it travel a long distance in a longer period of time then it should've taken. It had something to do with specialized wavelengths, and some greek characters that made my brain hurt at that time.
    It won't work with electrons though. They don't listen to physicists. Dumn electrons.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  6. #16
    May 2004
    http://www.davidnavone.com/amp.html
    http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-66A
    has 555 timer with adjustable pot. for 0-30 second delay I use one to delay my amp signal to relieve my system from having any boot startup noises.
  7. #17
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by XxAndyxX
    肚子笑痛了
    S60 Install
  8. #18
    Jan 2004
    Florida
    I thought they were using some special substance the light was being shot into. I know they stopped light, although it was only for something like a fraction of a second.
  9. #19
    Feb 2004
    PA, USA
    Yeah, I seem to remember rubies coming into play. It might have been the type of laser they were using though.
    The experiment I was thinking off was across the English Channel or something. It had something to do with a communications project. Something like using light instead of wires. They managed to slow it down to within like 90% the speed of light. I can't remember how they did it though, and still stayed within the laws of physics.
    I'll have to dig through the box of magazines to find it now....
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  1. Regulated 12 volt to 5 volt conversion - Howto?
    By psyclobe in forum Power Supplies
    Last Post: 04-21-2010, 05:24 PM
  2. WTB: 60 Watt, 12 Volt AC to DC Power Brick
    By chut in forum Classified Archive
    Last Post: 11-16-2005, 02:19 PM
  3. 12 Volt 250W,ATX WITH P4 CONNECTOR
    By xtreamvette in forum Power Supplies
    Last Post: 03-10-2004, 12:29 AM
  4. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 08:30 AM
  5. Replies: 0
    Last Post: 01-12-2002, 04:38 PM
