Results 1 to 10 of 19
Thread: "Delaying" a 12 volt signal?
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    It may be late, I may be a little fried from exams and the such, but I'm usually pretty quick on figuring out this kinda stuff.
    I need to "delay" a 12 volt signal getting to one part of a project I'm working on. Something like this....
    Switched +12v ----> Delay of sorts ----> Delayed Switched +12v
    I basically need to prevent a relay from turning on too quickly.
    (A huge length of wire won't work...so don't suggest it...)
    Any suggestions?
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    You can use an RC network to implement a delay. Search the forums for examples.
    Feb 2004
    PA, USA
    Just found it. See? Too much work, and not enough sleep hurts.
    Unless you're a programmer. But that was last semester.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    (A huge length of wire won't work...so don't suggest it...) <<< hahahaha
    Signature: [==||========] 20% complete
    Low Bitrate megamind's Avatar
    Aug 2004
    Netherlands, Rotterdam
    We use special delay relais. You have them in 2 versions:
    1: Give em power, they wait a period of time and switch in
    2: Unpower them and they wait a period of time to switch off
    You need the 1st one, ill look for you if i can find it somewhere.
    In the meanwhile here's a scheme:
    Its for 230v ill make a 12v version with a capacitator and a relais if you want to
    edit: you should look at the topic sticky in the forum
    http://www.mp3car.com/vbulletin/atta...tid=4455&stc=1
    051°55'30"N 04°34'31"E
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    I'm no expert on these things, but wouldn't using a 555 timer be easier?
    Feb 2004
    PA, USA
    No, the RC network is what I was looking for. Now, all I have to do is find a resistor that is low enough not drop the voltage too far. And match a capacitor to it.
    The 555 timer would work in one shot mode, but not for the size I'm working with.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
    Newbie Multiplayer's Avatar
    Sep 2002
    Denmark
    Kiltjim
    If you look in the sticky "scematics" theres som nice delay circuits, which are rather simple circuit's.
    Aug 2004
    If you need an easy way, just get the PAC TR-7 universal trigger module from your local car audio shop. It's also known as "Alpine Video Bypass" module on ebay.
    00 Galant
    armadaE500 P3-660 320M 20G, lilliput, audigy2NX, slim/slotLoad dvd/cdrw, cardReader
    sony rm-x2s, bu303, xmDirect
    xpPro sp2, frodoPlayer 1.09, iGuidance 2.0, custom voiceRecognition
    custom shutdownController
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Here's what you need to do; I just did this in my car yesterday. You need to buy a DEI pulse timer relay. The part number is 528T. Basically what it does is when it receives a signal (can be + or -) it will disconnect a wire for a set amount of time (you can adjust it from 0 to 90 seconds). Which sounds like what you are wanting to do. Here is a link for the part http://www.drdetailshop.com/528T.htm
    I saw them on ebay going for like 6 bucks and I got my from a local shop for $10.50. So I don't think you should buy it from the link above.
    I didn't read the replys so if this is redundent I apologize.
  1. Regulated 12 volt to 5 volt conversion - Howto?
    By psyclobe in forum Power Supplies
    Last Post: 04-21-2010, 06:24 PM
  2. WTB: 60 Watt, 12 Volt AC to DC Power Brick
    By chut in forum Classified Archive
    Last Post: 11-16-2005, 03:19 PM
  3. 12 Volt 250W,ATX WITH P4 CONNECTOR
    By xtreamvette in forum Power Supplies
    Last Post: 03-10-2004, 01:29 AM
  4. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 09:30 AM
  5. Replies: 0
    Last Post: 01-12-2002, 05:38 PM
