Results 1 to 10 of 16
Thread: Changing led colors on my computer
    Dec 2000
    Orlando FL (UCF!!)
    Red face Changing led colors on my computer
    How do you change the LED colors on your computer?? Also, hoa can i make my own power switch?
    .:@m֧p:.winamp.win98.pentiumII.10gig
    Jan 2001
    Adelaide, SA, Australia
    Post
    When you talk about LED colours, i presume that your talking about the power and HDD leds. Changing the colour is as technical as going to an electronics shop and buying differnt coloured LED's. On my case the led socket pulls out of the front pannel, then i just pull out the LED and replace it with a different one.
    re the power switch. Did u want to have a power switch up the front of the car with the poota in the boot? if so, put a toggle switch inline with the power cable that u run to the boot. Or you could get technical and have a relay in the boot run off a smaller switch in your dash.
    Just my views.
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
    Jul 1999
    Greensboro NC
    Post
    Its a trunk not a boot! sheesh!
    I know why Americans call it trunk because older cars actually had trunks on the back of them as storage space.....but where did the name 'boot' come from?
    Sorry not trying to start an international MP3Car incident...just wondering
    Catlas
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    hornet: Not quite that simple. LEDs can be switched between red, green, yellow and orange without a problem, but those colours are boring. Most likely, this guy wants to go to blue. However, blue LEDs require twice the voltage and current of regular LEDs. Therefore, an interface ciruit must be built. This can be as simple as a transistor switch with current limiting resistor, but it is not a plug and play situation.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
    Sep 1999
    Yarmouth NS, Canada
    Post
    Lots of people have placed blue LED's in place of case LEDs by just simply replacing them.. Some even change the LED's inside CDROM's etc.. A 5v rated LED will work fine from radio shack.. it just may not be as bright as it could (probably only 1.5-2v coming off the motherboard headers).. You shouldn't need a resistor in between either because it is only a few volts instead of trying to light the LED from 12v.
    Here is a 'tutorial' all about it.
    http://www.virtualhideout.net/guides...ds/index.shtml
    As for a power switch.. just get a 2 pole power switch.. cut the power wire where you want it and solder one end to the first pole and the other end to the other pole.. You cant get the switch backwards (it will just be off one way or the other depending on which end you attach to each pole)...
    Im assuming you want to put a switch on the inverter.. get an extention lighter socket from radio shack, also some fuse taps.. the fuse taps clip over top of the fuses and give you a point you can solder to.. Solder the power wire on the extention to this fuse tap.. attach the ground wire to an unpainted part of the vehicle chassis (ground).. You can cut the power wire like i said before and place the switch inline as mentioned above.... this is what I did with my inverter.. works great.
    [This message has been edited by Callahan (edited 01-31-2001).]
    MP3 Cavalier - http://www.mp3cavalier.com
    MP3 Grand Prix - http://www.mp3gp.com
    Jan 2001
    Post
    Catlas.
    I dont bloody know, i didn't invent the terminology, i just have to use it. Could you imagine all the looks i would get if all of a sudden i started calling it a 'trunk'? it would be like u calling it a 'boot' all of a sudden.
    mp3car FAQ - RTFF
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Post
    Okay then explain the 'bonnet'
    http://www.geocities.com/mr_bubba_zanetti/
    Bj
    Bj is offline
    Aug 2000
    Perth W.A Australia
    Post
    <font face="Verdana, Arial" size="2">Originally posted by DodgeCummins:
    </font>
    The bonnet is a special term used by only the Aussie's as we know what it really is! Hood! Hmph. That's what a rain coat has, not a car But I dunno, you US boys always have to change everything, you have to be different from the rest of the world. 110V, Imperial measure MPH etc, Trunk & Hood, Wrong side of the road, I dunno.
    Oh yeah, and why on earth do you call it GAS? LPG fair enough (if your car has it), but why call Petrol GAS? I suppose you got it from Gasoline....
    Oh this post will stir some ***** hehee
    [This message has been edited by Bj (edited 02-01-2001).]
    BjBlaster! Car MP3 & Carputer!
    bjblaster.com
    "The solution to one problem is only the beginning of another"
    Jul 2000
    Jackson, MS, USA
    Post
    <font face="Verdana, Arial" size="2">Originally posted by Bj:
    </font>
    Petrol = Petroleum? (or however its spelled)
    24 y/o w/ Silver/Red
    2000 Honda S2000
    http://www.squeezer.net
    Jul 1999
    Greensboro NC
    Post
    I think I might try using some Aussie terminology here in the US just to see what kind of funny looks I can get........Hey and maybe I'll start driving on the other side of the road too!
    Catlas
