I believe the MII is the newer version or upgrade to the M10000. If I was just starting a project I would probably go with the MII (assuming I decided to go with a via).
The M10000 is 1ghz, the MII is 1.2ghz and has a compact flash slot on board. I would look around the "show off your project" section and see what the newly completed projects are sporting.
LinkBack URL
About LinkBacks
