Results 11 to 20 of 27
Thread: What antennas are you using with your TV?
  1. #11
    Low Bitrate andyhardy's Avatar
    Mar 2004
    Bexhill, East Sussex, England
    More info. on the Phillips TV aerial range here...
    Phillips
    Cheers,
    Andy
  2. #12
    bakersfield, ca
    Quote Originally Posted by Batmanatthenewb
    I actually made adapters and hooked both my TV and Radio Extreme up to the factory car antenna. With a booster from radio shack, reception was real good on the TV. The radio improved considerably, but still wasn't up to HU quality. I have since put the TV on a dedicated antenna. One of the powered diversity ones on ebay. Reception was better with the factory car fm antenna and the booster.
    Batman
    batman, how did you make the adapter to use your existing car antenna, i was getting ready to hack up an old headunit to get the plug that goes in to the antenna and just do some soldering.
  3. #13
    Jan 2003
    Ruston, LA
    You can buy motorola connectors at radioshack, no need to hack up a headunit.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #14
    bakersfield, ca
    got a name for that, im looking online and can't find it
  5. #15
    Jan 2003
    Ruston, LA
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #16
    bakersfield, ca
    thanks!
  7. #17
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Wait frodo.. what am i looking at? Is that a device that would allow me to connect my car antenna to the coax input on my tv card?
  8. #18
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    Quote Originally Posted by Sonicxtacy02
    I used the car antenna adapter Frodo showed, coverted that to a regular cable fitting and plugged it in. Needed a antenna booster to get better reception. Also, be careful with what cable you use some of the standard "home" cable doesn't have enough shielding and you will get a bunch of static.
    Batman
  9. #19
    Constant Bitrate Lando's Avatar
    Apr 2002
    Batman, did you by any chance draw up a schematic?
    Aut cum scuto, aut in scuto
  10. #20
    Woodbridge, VA
    Blog Entries
    55
    thanks for the clarification. Now another question. Is there an adapter that would slit the wire coming from the antenna that would allow me to just use that antenna and connect to the tv card? I extended the antenna wire to the carputer and just touched one end of the coax to the wire and the reception was pretty remarkable. I think using that antenna with a booster would suit me just fine.
  1. Which antennas for tv cards?
    By barb3tta in forum General Hardware Discussion
    Last Post: 03-03-2007, 11:47 AM
  2. TV reception
    By SteveC in forum General Hardware Discussion
    Last Post: 04-22-2004, 05:03 PM
  3. Epia 9000 Problem w/ TV Out
    By blazinlow in forum General Hardware Discussion
    Last Post: 03-05-2003, 12:15 PM
  4. How I got TV in my Car (about antennas)
    By felix99 in forum General Hardware Discussion
    Last Post: 09-12-2002, 05:38 PM
  5. TV Antennas
    By ddt in forum General MP3Car Discussion
    Last Post: 08-25-2002, 10:06 PM
