Results 1 to 10 of 14
Thread: In-Dash LCD
    Constant Bitrate BrianMay's Avatar
    Oct 2004
    Lisbon, Portugal
    In-Dash LCD
    Has anyone built an in-dash lcd? I mean...a 1DIN case for you lcd? motorysed or manual! I'd like to try and make one but I have no ideia how to...!
    10x
    Aug 2004
    There are ways to build an manual one. Just get an in-dash housing from digitalww.com and fit a Xenarc or A Liliput in. There are instructions in www.digitalww.com
    As for automatic ones, I am planning to get the AutoCAN unit but it cost $990us.
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    www.digitalww.com sells an in-dash case that you can put an LCD in, as well as a complete unit with an LCD installed already.
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    Why dont you people ever search???? the tool is meant to be used. SEARCH GOD DAMN IT
    Oct 2004
    Lisbon, Portugal
    I did search...but I couldn't find no one who had built it.....with case included...I was thinkin' I could used a 1DIN radio case and fit the screen in there...but how? If I can't manage to do it I'm thinkin' of installing my screen above the phone
    Oct 2004
    Lisbon, Portugal
    little help here... ideas on alternatives to in-dash...(non-expensive ones would be great )
    Constant Bitrate RPI Geek's Avatar
    Oct 2004
    Schenectady, NY
    I'd be careful about mounting the screen above the phone in case the passenger airbag ever needs to deploy. If you wanted to remove the airbag you could put everything in there and it'll look stock.
    What are your plans so far? Will you be replacing the HU that's already there? Mounting it on top of/below it?
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
    Oct 2004
    Lisbon, Portugal
    CarPc in trunk, for now I want to keep my HU 'cause buying an amp to wire the sound would come as an extra cost....lilliput w/TS on the dashboard..but I don't want to cut my dashboard...as much as i'd like to have a very stock install I could never "destroy" my dashboard ...so I'm left with very few options :S I could move the phone to somewhere else but I'm not sure if the screen would interfere with passenger's legs.....
    I'm an open-minded guy...as long as no one tells me to "rape" my dashboard
    FLAC jbors's Avatar
    Nov 2003
    You can buy TFT indash screen for $150 and use it but it does not worth it...
    But why do you need big LCD in such a small car ? Can't you use your HU display for that ?
    Car pc integration with ease
    Car mediacenter
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Looks like you fit a custom made screen enclosure where your radio is and jsut have it fit in nicely so you dont have to cut your dash. You could copy the angle of the radio so you can see it better and just have the bottom of the screen out a bit. Also is that the ash tray below? you could pull this out and carry on your enclosure down to infront of the gear stick and put your DVD drive coming out fo there. The money you save on not buying a pull out screen mechanism would go a long way to paying for an amp. Best thing i found to do is make a mock up screen and just try positioning it around your car to see where it will fit.
  1. FS: in dash lcd housing
    By Motorcity in forum Classified Archive
    Last Post: 08-17-2004, 12:56 PM
  2. Looking for In dash vga + radio lcd
    By Chronic13 in forum LCD/Display
    Last Post: 08-12-2004, 02:22 PM
  3. 6.4/7 inch in dash LCD?
    By Rireal in forum LCD/Display
    Last Post: 01-23-2004, 10:44 AM
  4. Anyone want a Clarion 5.6" In Dash LCD?
    By gguy in forum LCD/Display
    Last Post: 05-30-2001, 11:29 PM
  5. Preview of my in Dash LCD install
    By Destin in forum General MP3Car Discussion
    Last Post: 01-27-2001, 11:48 AM
