hehehe, title sounds funny when read out loud...
hi.
search a lot and didn't come up with much info.
i'm trying to hook up a pocket pc (using pocket pc windows 2002) i had lying about. i read in some other posts that it's possible using vnc via the usual usb/activesync connection.
having trouble actually connecting the two together, search google etc and didn't come up with any usefull info. i've got the vnc viewer on my pocketpc, and i'm not too sure how to actually use it?
it asks for the host vnc server name in the form of "name:x" where "x" is some number i'm unsure of (maybe port?)
anyway, i've tried with my desltop's ip (192.168.1.12 over the lan) and also it's name "michael" and nothing. the vnc viewer on my opcketpc just dissapears...
any help greatly appreciated!
was planning on using it as a winamp remote (using the remoteamp software, which is working perfectly!) but then read about other people trying to use it as a mini lcd/display/remote so thought i'd try as well.
thanks again...
yes it does, Dr. Seuss
[H]4 Life
I'm a lesbian too.
I am for hire!
informative answers![]()
I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
www.neoterikos.com
are you able to access the network/internet from the pocket pc (i.e. can you go to google.com with the ppc browser?), if you can't then something is wrong with the networking part. I believe there is an option in Active Sync to enable/disable network connectivity through the cradle. If it does work, try using 192.168.1.12:5900 (default VNC server port), that should work.
How are you accessing the network with your pocketpc ?
You're going to need to get access to the local network.
[H]4 Life
I'm a lesbian too.
I am for hire!
yep, can access net throughthe ppc. it's going through my desktop (via cradle) and to router via wireless.
perhaps i'm using the wrong software?
i got the realvnc software from realvnc.com, bu didn't find a ppc version of their viewer, so just googled for one...
could this be the prob?
I have VNC working from my PPC to my XP desktop. The difference with my setup is that my PPC is running WM2003.
For the Pocket PC I used VNC Viewer from Allware and Real VNC on my desktop.
Your problem may be your router. You may have to open port 5800 to allow VNC to work...
Other than that, you seem to be on the right track - your methods for accessing your desktop with the PC name should work, but you also need the host number after the IP address if you're using that. Most likely something like "IP:0"
yep tried, 192.168.1.12:5900, and michael:5900 with no effect.
why would it go through the router? i was unde rthe impression i could use it derectly via the usb activesync connection, which is what i'm wanting it to do later in the car.
Routher Schmouter...
VNC uses network protocols not typicaly bound to USB connections.
keep your head in the game.
•Micke
