Results 1 to 10 of 13
Thread: This may be the dumbest thing anyone has ever asked
    Aug 2001
    Australia
    Post This may be the dumbest thing anyone has ever asked
    now as it says this may be the dumbest thing anyone has ever asked, BUT, I really need to be sure. okay, now no laughing!!
    when you got to the petrol (gas) station and fill your car up you have to turn off your car, completely.
    QUESTION 1: using time delay circuits do any of you have a way of like cutting power straight away? or is the inverter on not a problem in this situation?
    QUESTION 2: and Im fitting a LPG tank into the boot (trunk) of my car, will there be any problem having a wireless network running from the box sitting right next to it?
    I only ask this as I just yesterday noticed a picture on the petrol (gas) pump about not using mobile phones while filling your car.
    no smart arses!!! this is serious **** here! *lol*. no, serious any comments?
    Cheers!!
    The box said Windows 9x or better.. so I installed Linux
    There are 10 kinds of people in the world those who understand binary and those who don't.
    Sep 2001
    Post
    Your car uses LPG? interesting. Turning off any electronic equipment is for safe precaution. Leaving interver on surely let the current flow. I don't see any way of cutting the power when using time-delay circuit. You can add a switch manually turn off the inverter for safety. I didn't hear people's car exploding because they used mobile phone or even let the car running...
    When I was in other country, taxi drivers were using LPG(all of them...it's the law...) and they didn't even turn off the engine.
    I am sure there must be an incident where car exploded but it's not common...
    Not useful, but just my opinion on this.
    Jul 2000
    Post
    MikGan: I think all the rules and stuff you are supposed to do at a gas station come from lawyers with too much time on their hands to come up with way people could sue. While there is a chance that a mobile phone could cause a spark I have to believe its very very very low. Those signs are there mostly in the case it does happen the gas station is safe from damages and they have the right to sue the person for damages.
    Awol
    my $0.02 cents (value is based on the intelligence of the person reading this message)
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Wink
    The danger is in fuel vapor. Gasoline is extremely volitile and turns into vapor at a low temp. So if you are filling your car, vapor is pouring out of the filler (unless you have one of those pain in the A$$ vapor retriever nozzles like in California.
    If you have a large concentration of vapor and your cell phone is nearby, your cell phone could fill with the vapor, then if you have some kind of ignition source or short in the cell phone, and enough density of vapor, then it could explode.
    I think that when you fill up with LPG it is a closed system, only vapor is released when you unhook the 'nozzle'. Unless you have a leak or bad connection I would say that you are safer with the LPG.
    But lets face it, there are people that smoked and filled up their gas tank and didn't explode.
    I think that anything is possible, but the probability decreases significantly with things like this.
    Think about it, a 1000 watt stereo in your car has a greater chance of making a spark than your .5 watt cell phone. A relay pack next to the tank filler cap would run closer to the 1000 watt stereo in ignition danger in my opinon.
    Hope my rampling post answers some question somewhere.
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    Actually, the dumbest question someone ever asked of me was "do these staires go up or down?". But I digress...
    I don't want to get sued if you blow yourself up, but I have always left my player on while I filled up, and never had a problem. Bear in mind that I do not have an inverter, and my player will run regardless of whether the car is started or not. Personally, I'd be more worried about the spark from a leaking ignition wire than any issues with the MP3 player, especially since the player is "sealed" in the car.
    As for cell phones, it's just a whole load of BS. If it's even possible, there's a 1 in a billion chance that a cellphone will create a spark. And in all realistic expectation, you'd need a material like steel wool, which it's shape making it resonate at the exact frequency of the phone transmission. Don't worry about it.
    Hell, my ethernet connection is in the gas filler hole.
    [ 10-19-2001: Message edited by: Aaron Cake ]
    May 2001
    Australia
    Post
    My understanding of LPG is that there is a solenoid valve IN the tank to cut the flow of gas to the engine when the car is switched off. The tank is also complelely grounded to the car body so I would suggest there is no risk perhaps unless you are filling up(even then it would be so tiny. Id live life on the edge. I'm sure you are more likely to die on the way to the gas station). As for the mobile phones, I have been told there are cases where they have started fires because of the voltages they induce in metal objects(I was told it happened near where I live but I would assume it's an urban myth). It seems rather unlikely though. I think there is metal braiding in the hoses on the bowsers but I'm sure those things are grounded 100%.
    Newbie maxgtr2000's Avatar
    Jul 2006
    As the other post said the danger is the fuel vapors possibly igniting with a cell phone. I don't turn my car off anymore, the other danger is in static electricity so i don't enter the car anymore i just stay at the pump. Always ground yourself before pumping when wearing staic inducing clothing, wndbreakers, sweaters, etc. http://www.youtube.com/watch?v=k4r5-8doAYw
    I'm surpised how calm this chic was.
    Mar 2007
    Central Florida
    I agree, static discharge is common with cars, especially in cool, dry climates. You should try to discharge yourself and the car by touching it's surface after you've exited and before you pump. I think most of the time it's hard NOT to do this, since you have to open the cap anyway.
    The cell phone thing is BS. I think it is more of a "don't get distracted while talking on the cell phone and dump gas all over everything" issue. And in my opinion if you can't stay off the cell phone for the short amount of time it takes to pump gas, then you probably shouldn't be driving a car.
    Don't know anything about LP, but I suspect you are fine as long as you are careful.
    Good luck.
    Jun 2007
    Tampa, Florida
    I completely agree with Aaron Cake..... There was a TV show (Myth Busters) that tried everything scientifically possible to ignite a fuel source with a cell phone. Couldn't get a single viable spark........ There's never been a recorded case of ignition by cell phone. I personally leave all my gear on while refueling just to avoid the startup time!
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    There ARE in fact recorded cases of cell phone explosions at gas stations, but you have a better chance of getting struck by lightning, twice, at the same gas station, than having your cell phone explode on your face.
    Back to your original post... I never ever turn my engine off at the gas station. Our pumps here in the states do have signs on them say "Turn Off Engine." But I don't. Never had a problem... been driving for 15 years. Doesn't really address your questions... just an FYI.
