Results 1 to 10 of 13
Thread: xbox questions..
    Oct 2004
    xbox questions..
    Hi, i posted earlier about using a laptop as a carputer, but since then have also been looking at an xbox and have done alot of research.
    From what i have found out, they can be chipped and the hard drive can be upgraded to something larger. Then linux can be run.
    I have also found a GPS program built for linux for europe which is where i am from luckily. But, how does the GPS reciever connect to the xbpx, through a usb port right? but what about drivers etc. Will the drivers that come with the gps system work with an xbox?
    I would also like to know what the sound quality is like from an xbox
    thanks.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    The Xbox has a digital audio out. You can get adapters to allow you to plug regular USB devices into the controller ports of an XBOX (which are just funny shaped USB). If the GPS unit has Linux drivers you sjould be OK...as long as you're familiar with Linux.
    Oct 2004
    i've never used it before lol
    Quote Originally Posted by daworkz
    thanks.
    Actually there are several gps programs for linux. Any nmea gps should work with gpsd (which is what most gps programs use to get the data) if it is usb you may have to set the gps to read from /dev/usb/ttyUSB0. For carputer software go to http://sourceforge.net/project/showf...group_id=43989
    And if you never used linux do yourself a favor and use a major distro like mandrake or fedora.
    Feb 2004
    Green Bay, WI
    this is what you use to connect the gps to the xbox
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Or you can just hack up an xbox extension wire and wire up to normal usb.
    I've done this the other way around to hook my xbox controller to my computer, but I'm sure it goes both ways.
    Tidder
    Try RevFE
    Constant Bitrate Malenko's Avatar
    Jul 2004
    Newark,De
    Quote Originally Posted by Tidder
    thats too funny not to quote.
    actually the best method Ive done is to to splice a USB extention cable into the XBOX controller's breaker cable:
    controller-round break away-USB out-USB IN-round plug into XBOX plug-XBOX
    then you unhook it where the USB thing is if you want to have USB into the XBOX or if you wanna use your XBOX controller with your PC
    Jul 2004
    Chandler, AZ
    Isn't one of the wires in the Xbox USB a +12V?
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by Malenko
    Give me a break man. You know how it is when you're thinkin' something, but it doesn't come out quite right, but it makes sense to you because you're the one that thought it up? Yeah.
    It goes both ways...
    I meant that if you can hack up an xbox controller extension with a normal usb connector to use a controller with your PC, then you must be able to hack up the same cable and put on a usb receiver and use it with the Xbox.
    C'mon now...
    Tidder
    Try RevFE
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    Adapters for XBox to USB and for USB to xbox can be bought for cheap or made for cheap do a litte
    .... do we have a touchsceen driver working for linux yet ?
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
  1. Replies: 16
    Last Post: 03-27-2008, 01:30 PM
  2. modified xbox instead of a PC?
    By hydraulix in forum General MP3Car Discussion
    Last Post: 12-05-2005, 12:14 PM
  3. Linux Build or Xbox Port???
    By boschk2002 in forum FrodoPlayer
    Last Post: 01-09-2005, 01:43 PM
  4. Ai-Net and XBOX and other ideas
    By Gavroche in forum General MP3Car Discussion
    Last Post: 10-18-2004, 12:55 PM
  5. Few questions about my current setup (xbox modded) migrate to PC...
    By Urinemachine in forum General Hardware Discussion
    Last Post: 11-13-2003, 05:24 PM
