Results 1 to 7 of 7
Thread: LCD Covers
    May 2001
    Vancouver, BC
    Post LCD Covers
    K, im tryin to make one of these for my Civic, if anyone has ANY sort of experiance please help me out a bit, hehe, so far what im doing is taking some plexi i have left from my case, cuttitng it to size, then getting some balsa wood (from old remote plane), cutting the Honda emblem outa that (a square w/ a H in the middle)
    Since i cant cut the H out of the square im making 2 layers
    Layer 1 = Square
    Layer 2 = H (in the middle of the square)
    glue the layers togeather, then glue them in the middle of the plexi cover, then covering it all with vynal. Like i said, its a huge experiment, but if you have any idea, please give me some ideas =] Also, what kinda glue is best for vynal, the fabric lady said spray on, but that didnt work so im giving that cement stuff a try. Il show you guys the final product in a bit =]
    this one looks sweet, but im not aiming that high, id only set my self up for a big let down.
    [ 10-21-2001: Message edited by: Treven ]
    Jun 2001
    netherlands
    Post
    dont be fooled about the looks of the logo !
    it is a thin layer of vinyl traced in the logo and then glued on the wood.
    then cover the total again in vinyl.
    if you use something too thick for the logo it will not look right.
    i did a simular thing a while ago on my subbox.
    time for the sig:
    '00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
    May 2001
    Vancouver, BC
    Post
    Ahhhh, that makes it so much easier #@$
    With the balsa wood i had troubles cause it kept breaking when i tried to do the H in the middle. Doh, now that you tell me this, it will be soooo much easier, thanks.
    Still, any ideas for glue ?
    and should i use plexi or wood ?
    Jun 2001
    netherlands
    Post
    i used mdf (medium density fibreboard) for the panel and traced my logo on the same vinyl as i used to cover the entire thing up with.
    i cutted out the logo with a razor blade.
    glue the logo on your board using spray glue.
    then spray glue over your board and your logo and the cover the whole in vinyl again and use an hairblower to stretch/soften the stuff when you pull it over your board.
    good luck and keep us posted
    time for the sig:
    Oct 2001
    Post
    where do you buy the vinyl and how much does it cost approx?
    Aug 2000
    Post
    Originally posted by mr0range:
    <STRONG>where do you buy the vinyl and how much does it cost approx?</STRONG>
    fabric store, the price ranges based on texture and color ($3-&9 a yard)
    Oct 2001
    Chicago, IL
    Post
    You said the spray glue didn't work before. Do be cheap! Buy the 3M Sprayment! That's the best there is. Hope this helps. I used to install at a car audio shop. Anymore questions, I'll answer for ya.
