Results 1 to 10 of 11
Thread: Yep, another audio noise thread
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I got Mikes Hybrid XM and the XM AMD1000. Used RCA cable from the XM receiver (AMD1000) to the RCA+1/8 adaptor, which I plugged into the "Line IN" on my sound card. The sound is very low and horrible. I ended up unplugging it and splicing the RCA cables into the same RCA cables to go from the sound card to the headunit (for now to get good sound)
    I'd really like to use the line in on the sound card instead, any idea why it sounds like crap?
    All volumes in XP are all the way up.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Variable Bitrate blurp's Avatar
    Sep 2003
    Hampshire, TN
    More info? What sound card do you have?
    www.bradleyjacobs.com
    There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
    Jun 2004
    South-Central PA
    Not sure, found this on my spec. sheet: Analog Devices AD 1885 AC '97 on-board codec. It's attached/part of the MB (Intel (Kitty Hawk 1.5) Motherboard 1.2-GHz Celeron R1)
    Sep 2003
    Hampshire, TN
    It sounds fine with normal PC speakers?
    Jun 2004
    South-Central PA
    Haven't tried that, but my mp3's sound fine, this is when the audio is straight from the sound card to my headunit.
    It's when I use the "line-in" (source from MXD1000) it sounds bad.
    What are you saying? It couldn't be a speaker issue when they sound fine playing mp3's, could it?
    Sep 2003
    Hampshire, TN
    Just trying to troubleshoot...Soundslike there may be something wrong with the soundcard and/or plug on the mobo. That is, if you're using the same cables to the pc as to the HU.
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    you're probably pumping non.linelevel signal into line-in for that horrible sound.
    •Micke
    Jun 2004
    South-Central PA
    @blurp...Yes, same cables. I ended up unplugging it from the line-in and (with more adaptors, plugged the XM cables directy into RCA cables that go from the soundcard to the HU. Sounds fine that way, but I can't record. (No big deal)
    @grepzen..."non.linelevel signal"??? The XMD1000 (XM Receiver)does not have a volume control, is this what that means? That's why it sounds bad?
    Sep 2003
    Hampshire, TN
    Quote Originally Posted by grepzen
    Shouldn't sound that bad, or low. I've used mp3 players, tape decks, turntables, and even a walkman piped through line-in. None of them sounded like that, and none of them were line level.
    Oct 2004
    I know you prolly checked this, but I wanted to bring it out anyway:
    Are you sure you plugged it into the Line in and not the Mic in??? It's just something to double check.
    Also, did you make sure that the port is setup in windows to be a line in and not surrond out of quadrophonic out? To do this, go to Control Panel->Sounds and Audio Devices, then click the lower Advanced button. In the Drop-down list, Desktop stereo speakers should be selected unless you want to use multi-channel (> 2 channels) out, and that usually makes line in and mic change to other things.
    Did you check the volume properites to make sure the line in level is up, and that the line in is selected? To do this, double click the speaker in the taskbar (or, if it isn't there, go to Control Panel->Sounds and Audio Devices then click the upper Advanced button). Goto Options->Properties. Click the dot next to Recording. Make sure Line-In is checked and click ok. Find the Line-In volume, make sure it is up, and make sure the Select check box is checked (Under Line-In).
    ColdPhreze
  1. Noise on audio from laptop
    By pip in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2006, 08:09 PM
  2. Yet another audio noise thread....
    By gambit32 in forum Car Audio
    Last Post: 03-06-2005, 01:41 AM
  3. Yet another noise thread: Weird problems
    By Knutti in forum Car Audio
    Last Post: 09-17-2004, 12:56 PM
  4. Another noise thread
    By BeamRider in forum Car Audio
    Last Post: 09-09-2004, 06:28 PM
  5. Audio noise, only with Lilli LCD on.
    By muldrick in forum LCD/Display
    Last Post: 08-11-2004, 07:45 AM
