Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: I got a tough one. Electrical Guys Look
  1. #11
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by choyak
    But as for the wire, if it is functioning properly without it, don't install it
    Well ofcourse.
    I am just trying to set everything up correctly and since my computer is not in a good metal case (mounted in glovebox) i wanted to make sure that there was sufficiant ground between the motherboard and the PSU since i do have somewhat of a noise problem that i am trying to beat Noise before Opus turns computer on . Obviously i will take startup noise over a non working shutting off computer.
  2. #12
    Jan 2003
    Ruston, LA
    cool, I was right
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #13
    Jan 2004
    California
    yes you were!
  4. #14
    Jan 2003
    Ruston, LA
    nobody has any idea what we are talking about
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  5. #15
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    肚子笑痛了
    S60 Install
  6. #16
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Sorry, but to me 'floating ground' implies that a connection that is supposed to be grounded is not grounded. This can cause all sorts of dangerous conditions, but that is not what is happening here. It seems that the OUTPUT of the Opus is what the mobo 'ground' or preferably called 'LVCOM' (low voltage common) is connected to, which is different than 'ground' which is the car chassis, and that is not really 'ground' either, the only real 'ground' is the good old earth!! But as for the wire, if it is functioning properly without it, don't install it
    I am by no means an expert, but as far as I have be taught, ground is a relative term when used in circuits. I tried to explain it in terms that could be understood by antimatter and anyone else who read this thread.
  7. #17
    Jan 2004
    California
    the awewsome magnificant powers of IM
  8. #18
    Aug 2002
    Quote Originally Posted by frodobaggins
    What else is new
  9. #19
    Jan 2003
    Ruston, LA
    Quote Originally Posted by meddler
    What else is new
    Bada Bing !
    True
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  10. #20
    Jan 2004
    California
    I am pretty knowledgable about electronics. I can read your basic schematics and build small projects so i guess you could get a little more technical with me
    I do have the thing working but i just want to make sure that this won't cause any bad side effects down the road.
    Thanks by the way for you help
  1. Replies: 6
    Last Post: 09-30-2004, 05:38 AM
  2. hi guys, was reffered to here.
    By ares in forum General Hardware Discussion
    Last Post: 06-27-2004, 12:56 PM
  3. Replies: 1
    Last Post: 02-29-2004, 10:32 PM
  4. Replies: 13
    Last Post: 12-12-2003, 02:26 PM
  5. how did you guys anchor your computers in the trunk?
    By Heedunk in forum General MP3Car Discussion
    Last Post: 09-15-2001, 11:30 PM
