Results 1 to 10 of 11
Thread: Hooking Car alarm into PC To monitor
    Oct 2004
    Canada
    I am going to be puting my car pc in this weekend. I was wondering if anyone has there alarm hooked into their Car pC. If you do what is the name or what adapter did you use.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    What you want to do with it?
    This is an installed by cproaudio on this
    97 Toyota Tacoma truck. to see what a car alarm and computer can do.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Nov 2003
    Los Angeles
    If the purpose is to protect the car pc, best bet would be to put a spring switch behind the unit, so when you pull it out, it automatically goes off.
    Elsewhere
    Quote Originally Posted by cyberdrakon
    That or some sort of shock sensor, perhaps.
    How about the Wiki?
    Oct 2004
    Canada
    I was thinking more in having a connection from my alarm system to my pc via USB or RS232 and monitor the system ( like a log sheet on how many times it went of and such)
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Unless your manufacturer makes a kit for something like this, you would have to use a scotch-lok to make an IO cable from the computer of the alarm. This actually wouldnt be very hard, you can find the ends to IO connectors at RadioShack. Then just write a program that captures all data from the port, set off the alarm, find the data that was sent at that time, and write a program that watches for that value.
    Quick! To the Popemobile!
    Katy TX
    Here, I took just about all of the guess work out of it for you.
    Code:
    import java.io.*;
    import javax.comm.*;
    public class AlarmInterface implements Runnable
    	InputStream  input = null;
    	OutputStream output;
    	String activationString = "asdf";
    	SerialPort serialPort = null;
    	public AlarmInterface(String name, int baud, int timeout) throws Exception
    		CommPortIdentifier portId = CommPortIdentifier.getPortIdentifier(name);
    		serialPort = (SerialPort)portId.openPort("GenericSerialReader", timeout);
    		serialPort.setSerialPortParams(9600, SerialPort.DATABITS_8, SerialPort.STOPBITS_1, SerialPort.PARITY_NONE);
    		serialPort.setFlowcontrolMode(SerialPort.FLOWCTRL_NONE);
    		serialPort.enableRcvThreshold(1);
    		serialPort.enableRcvTimeout(timeout);
    		int rosStatus = 0;
    		System.out.println("Open device called");
    		output = serialPort.getOutputStream();
    		input = serialPort.getInputStream();
    	public void run()
    		try
    			if(output.readLine().compareToIgnoreCase(actiavtionString) == 0)
    				//Write and call an log function here
    		catch(Exception e)
    			System.err.println(e);
    	public static void main(String [] args)
    		Thread mt = new Thread(new AlarmInterface("Alarm Reader", 9600, 1000));
    		mt.start();
    Edit: Yeah, it's in Java. You will need to download the javax.comm package for this to work.
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    im interested in seeing this work..
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
    Oct 2004
    Canada
    Thanx Bio
    I am not a programmer but i can do the wiring and install this is a project to try thou
    I seen that the clifford G5 alarm can also do this right off the shelf with a serial connection that i seen today.
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    I want to get the Clifford G5, but I just have to find who actually sells them in Australia. They are suppose to be installed by a accredited installer. They won't just sell you the alarm If anyone knows where I can get one, let me know.
  1. Car PC gives edless possibilities!
    By Smukkasen in forum Newbie
    Last Post: 06-27-2004, 12:09 PM
  2. need everything for a PC in car??
    By Hollis613 in forum Wireless Communications
    Last Post: 04-23-2004, 02:42 PM
  3. will pcchips 748 mobo work as a car pc?
    By hud in forum General Hardware Discussion
    Last Post: 03-10-2004, 09:55 PM
  4. About power Supply to PC in car
    By Sk8te in forum General Hardware Discussion
    Last Post: 11-11-2000, 11:39 AM
  5. CRT monitor in car
    By TokaTola in forum General Hardware Discussion
    Last Post: 02-27-2000, 04:01 AM
