Results 11 to 20 of 22
Thread: PCI card shaking loose
  1. #11
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    If you use electrically-inert hot glue (almost all hot glue is anyhow, we've used many different brands in our service lab), pop a dab on the card where it joins the socket, at both ends of the socket, on both sides of the card. JUST USE A SMALL DAB. Don't run a line down the socket, or you will NEVER get the card out again without damaging it or the motherboard or both.
    EDIT: Incidentally, some shady fly-by-night computer companies will use this method to prevent you from upgrading your machine without going through them. That way, if you bring it in for service, and the hot glue is gone, they know that you messed around under the hood, and can now charge for service, even if the machine was otherwise under warranty.
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
  2. #12
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    it is called loctite and it is made by 3M you can get it at any auto parts store.
    many types for locking down screews -
  3. #13
    Oct 2003
    you may also want to think of switching to a all in one MB so then you wont have any cards to come loose. also may make it easier to work with as far as space,and may make for cleaner install. as far as the usb card just use a hub.
  4. #14
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    DONT USE LOCTITE!!!!
    Loctite is for screws, it IS not conductive and is made to seep into places, and will likely seep into the contacts of the connector, insulating the card and making it inoperable.
    He apparently didnt read the FULL post.
    Again...
    DONT USE LOCTITE!
    I would recomment building a bracket to support the card, you have plenty of places to hang it from. Supporting the other side of the card should keep it in the slot. I bet it is shaking loose due to it flexing back and forth. A simple strap would probably be the easiest, and least destructive to the components,
    2005 Ford Focus ST
  5. #15
    Nov 2003
    Detroit MI
    Quote Originally Posted by gospeed.racer
    Again...
    DONT USE LOCTITE!
    I agree heavily... OMG DON'T USE TEH LOCTITE! I mean WTF?! Loctite is for screws, and WILL mess up your system! Imagine using it, then trying to pull the card out when it stops working, only to discover all the card edge contact ripped off and still stuck in the socket!
    Gospeed's idea is also quite sound. That, or you could use the hot glue.
    The ALEXIS Project
    Color Coding :
  6. #16
    Low Bitrate odleon's Avatar
    Atlanta
    yea, im not talking bout loctite. only the video card shakes loose(must be teh weight), the usb card is fine(usb 2.0 card, comp is ~3-4 years old) prob. go with hot glue as it seems to be teh quick and easy way out of this.
  7. #17
    Elsewhere
    Quote Originally Posted by odleon
    There's a company that makes a plastic bar that will screw into the PCI slot and help to hold in the card. It does require a longer-than-normal screw.
    Link: http://www.directron.com/cardkeeper.html
    How about the Wiki?
  8. #18
    Newbie PCGUY112887's Avatar
    Oct 2004
    Illinois, Near St.Louis
    It appears the tab on the cards where it normally screws into the side of the case is right next to the plastic in the glove box? If so... just use some tape there for a cheap ghetto solution
  9. #19
    Atlanta
    i took off the metal to make it fit. with it on the glove box door wouldnt close.
  10. #20
    Take some electrical tape and run a strip along the edges that connect the pci socket to the card.
    Removeable + non-conducting + inexpensive = decent solution.
  1. PCI Graphics or Sound card - EPIA M10000
    By ZimZimmer in forum Newbie
    Last Post: 08-05-2004, 10:02 PM
  2. Help finding a 54g PCI wifi card for Procase'd carputer
    By NJay in forum General Hardware Discussion
    Last Post: 01-21-2004, 03:04 AM
  3. need PCI nvidia video card with Conexant TV chip
    By Onyx in forum General Hardware Discussion
    Last Post: 11-12-2003, 03:14 PM
  4. PCI Graphics card with TV Tuner in UK?
    By phoTToniq in forum General Hardware Discussion
    Last Post: 03-21-2003, 09:38 AM
  5. PCI card riser card
    By allenruble in forum Classified Archive
    Last Post: 11-25-2001, 07:51 AM
