Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Anybody wired there Horn to the computer?
  1. #21
    Newbie Bigmaxxin's Avatar
    May 2004
    P-Ville
    Is there anybody out there that knows if there is a production car on the market that has some kind of computer attached to the horn system??
    everycar since the 1978 accord, man they were ahead of their time...
  2. #22
    Newbie popuptoaster's Avatar
    Aug 2004
    Essex, UK
    just wire an external speaker to the pc so you can play whatever you like through it, it was a standard socket on most CB radios, so you could use em as a PA system. depends where you are as to whats legal to play though.
  3. #23
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    You could wire it so that when you honk your horn, a display on your grill says "Move that piece of ****!" Backwards of course, so they can read it.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
  4. #24
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Quote Originally Posted by popuptoaster
    MOVE, *****! Get out the way! Get out the way *****, get out the way!
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
  5. #25
    Whistle Tip pimpJ's Avatar
    Metro, TX
    Quote Originally Posted by deadweasel
    woo wooo ! gotta love the luda
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
  6. #26
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by IntellaWorks
    Here's a use for wiring the horn to the computer..
    Everytime, you swear in your car the horn beeps.. so if someone cuts you off "F**K You A**H**E!" the computer gets the voice recognition and honks the horn...
    肚子笑痛了
    S60 Install
  7. #27
    Aug 2004
    Syracuse, New York
    Does anyone know if horns(i mean stock) come made with a predesigned sound or is it an add on compnonent?
    2.4 Ghz Prescott, 512mb XMS Ram, 160 gb Sata,
    10% Finished : Sitting on my floor in my room
  8. #28
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    Quote Originally Posted by Mirrogas
    i believe its a diaphram that you pass a specific amount of voltage thru and thus it resonates at its given frequencey creating a harmonic waveform. that is audible to us humans
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
  9. #29
    Nov 2003
    Detroit MI
    Some are diaphragm-driven, as previously suggested. These are the ones that most compact cars have. The "roadrunner" beep. Others, that sound almost like trains, that can be found in large sedans and pickups, are air-driven.
    If you apply higher or lower voltage to the diaphragm version, it ceases to resonate properly, and usually won't make a sound other than a weird metallic tick when you hit the horn. These types of horns have small adjustment screws on them, since as they get older, they wear down, and have to have their "flap limit" adjusted to compensate.
    Adjusting the voltage to the air-driven types doesn't change the sound too much. You might get a slightly lower- or higher-pitched honk out of them, but the motor inside will burn out much more quickly.
    There are digital versions of horns (all after-market) and some air-driven ones that you can adjust their pitch and sound. Nothing stock is too adjustable, although if you really want to scare the bejesus out of someone, get like four of the air-driven ones and mount them under the hood of a Civic. Instant freakout!
    The ALEXIS Project
    Color Coding :
  1. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 10:51 AM
  2. Cutting power to USB after computer has shutdown
    By lookinco in forum Power Supplies
    Last Post: 05-17-2006, 02:05 PM
  3. FS: Car Computer Setup - Everything you need!! Pics Galore
    By EBoundEE in forum Classified Archive
    Last Post: 06-19-2004, 10:41 PM
  4. computer theft tracking - PC PhoneHome
    By Question in forum General MP3Car Discussion
    Last Post: 07-16-2003, 03:14 PM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
