Results 1 to 4 of 4
Thread: Calling All Masters Of Tech
    Oct 2004
    Exclamation Calling All Masters Of Tech
    First let me thank you guys first that answer..... Now here is my delima I am NEW to the incar PC scene. Below are a list of Items below and the Items I need advice on, thank you for your help and speedy answers.
    1.) System Board VIA EPIA MII 1200 / VIA NEHM M1000 which one and why
    2.) Memory 512 Mb
    3.) Hard Disk 40 gig
    4.) Slim line slotload CDRW/DVD-+RW
    5.) Power Supply Opus power supply / Snap-in power supply with ITPS which one and why
    6.) TFT LCD TOUCH Lilliput 7" / Xenarc 7" / Lilliput 8" / SP7 VGA 7" '' which one and why
    7.) Possiable X-Box install with DC power supply can it be done instead of runnning an inverter
    All of the items above with expection of the xbox will be installed in a custom console below and the xbox under the seat with wireless
    controllers. These Items will be in my single cab F150.
    Thanks Again
    "Justice may be blind but it can see in the dark"
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    1) It's been discussed.
    2) your set
    3) your set
    4) your set
    5) It's been discussed.
    6) It's been discussed.
    7) Now that something I don't thinks thats been discussed, and I don't have an answer either.
    Sorry if I didn't help much, but everything you need to know has been already discussed countless number of times. We can't tell you to buy this or that, you need to do some research and figure out what will suit your needs? What is with in your budget? What you plan on using the system for?
    There are many factor that need to be taken into consideration before you purchase something, so grab your self a seat, click the SEARCH button and enjoy some quailty reading.
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    xBox Power Supplies on this fourm and on
    Oct 2003
    all seem fairly reasonable components, work out what you want to do with the computer, how much power (not electrical) you actually need to achieve this goal and then work out how much it will cost compared to how you can afford.
    If money is no object then go for the top of the range of everything, if money is an object work out what is the most imortant to you and spend wisely in that area.
    One last point, the ITPS apparantley doesn't survive crank, stick with the OPUS or a carnetix if the budget don't go that far.
    if you can't find time to do it right, when are you gonna find time to do it over.
  1. Replies: 20
    Last Post: 11-08-2004, 10:41 AM
  2. Tech Support for Backlighting (EL) and Inverters offered
    By Electrolumin in forum LCD/Display
    Last Post: 09-01-2004, 11:42 PM
  3. Calling all Power Supply gurus!
    By netgroover in forum Power Supplies
    Last Post: 02-05-2004, 06:04 PM
  4. Calling LCD screen owners
    By AlienEclipse in forum Software & Software Development
    Last Post: 10-02-2003, 06:03 PM
  5. For the love of tech support
    By ShinkunoNamida in forum Off Topic
    Last Post: 05-21-2002, 01:12 AM
