Panasonic CW-8123-B. Check it out.
Can anyone recoment a good slimline slot load dvd drive ?
Newegg has them.Originally Posted by jdub421
Search for slot loading...
-Mario
good advice.. new egg has them.. i am ordering one myself.
may I hijack this thread for another question??
I am a little confused on coversion and power of drive.
Im buying a slimline to ide coversion piece.. then
I need a ide to usb 2.0 piece.. Where is this available?
Also I am planning on running the usb into a port hub. Does
the drive get power directly to drive or from hub. I plan on using the
opus supply.
Carputer in design stage...
Currently working on Lilliput In Dash Install...
MII 12000 + 512Mb Ram + Panasonic Slim DVD, CDRW + Lilliput 7" + Opus 150W + 3.5 120gb Drive... most parts on order!!
I guess this would depend on the converter if it had a regular power connector. I would suggest running power straight from the OPUS since I doubt USB's 500ma limit would power that drive.Originally Posted by biglips31
I looked at the MAPOWER that newegg sells and contacted the manufacturer. They said they don't recommend with the USB powered model, but the Firewire model was fine...
Just my thoughts though.
Anyone else?
-Mario
This has been discussed at length several times - do a![]()
Yo Pip,
If you take the time to respond why dont you just answer the question. I dont post often and have been here for a little while. when i searchalot of things do come up and after reading the postings I am still a little confused, hence my post. Im sorry but Im not as smart as you i guess.
Thanks Pip,
I finally got it.
I could run my usb connection to my usb 4 port or to the computer but I still want to supply my 5 volt power to the drive AND the 4 port via the opus power supply.. Do i have now?
Check out the link below. It's to an e-tailer that offers a Pioneer DVR-K05 slimline slot load Dual Layer DVD burner. It only uses 4.8w peak. And it gets it power directly from the USB, so no extra power cable is needed. It comes as an external drive, mine should be in the mail soon, i'm going to attempt to remove the drive and the slimline-usb converter and mount it bare.
http://www.dfwdepot.com/dvd-ram/inde...products_id=82
