Results 1 to 10 of 15
Thread: TO upgrade or not?
    Constant Bitrate DJKhan85's Avatar
    May 2004
    Boston, Mass
    Question TO upgrade or not?
    I've had my epia m9000 installed and running for a few months now. I've found that the onboard graphical capabilites of this board is very close to absolute suck. I don't get smooth playback of any video files. So here comes my question. Can the onboard graphic accelerator on the new epia motherboards (MII 12000) handle divx, and dvd smoothly? If it can't should I just purchase a cheap PCI graphics card. Something like a radeon 9200.
    Also for all the peeps with the new board, 1 ghz and over, does it seem sluggish at all or does it seem to power through any obstacles?
    So in recap its either new mobo or new video card. Which would be better in the long run?
    Computer:
    COMPLETE SYSTEM OVERHAUL!!!!!!
    STAY TUNED IN THE UPCOMING WEEKS!
    Low Bitrate andyhardy's Avatar
    Mar 2004
    Bexhill, East Sussex, England
    I can't tell you about the MII 12000 but I am running a M10000 and DVD playback (using PowerDVD codecs) and DivX playback through Mediacar seem silky smooth for me - if a little jerky when running sat-nav in the background (when direction changes occur etc.) - I'd imagine the MII 12000 would run even better than that
    Cheers,
    Andy
    Newbie Skorpion's Avatar
    Jun 2004
    Melbourne, Australia
    Quote Originally Posted by andyhardy
    Cheers,
    Andy
    so you can play divx and xvid encoded movies no problems? on my m10000n i get the video and audio going out of sync, which i assumed was because the cpu wasn't powerful enough. but if you can run them fine, it may be another issue. are you using the onboard video and audio?
    Mar 2004
    Yep - I'm using onboard video and audio, no problems.
    I've got all the latest codecs installed including PowerDVD ones for DVD playback.
    Codecs
    I don't recall doing anything particularly special to get the video to run properly - it just seemed to work ok
    I had tried DivX/DVD playback on an EPIA M800 system before and found the playback to be painfully jerky and out of sync, made even worse when running sat-nav in the background.
    HTH,
    Andy
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    It's not as much the graphics card, more the processor that will make the difference.
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Jun 2004
    Sydney, Australia
    Does that mean getting a PCI video card for my Epia 800 wont help my situation? It seems to play divX alright (directshow or some codec like that), but i've given up on the idea of playing DVDs, much less while GPS is running...
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    just wanted to jump on board with this topic
    BossTone74
    Maximum Bitrate PTCruiser's Avatar
    Oct 2002
    Switzerland
    Epia M 9000 & MII 12000 as the same video card (CLE266)
    A new GPU with mpg4 harware accel. will be added in the new Epia SP serie (CN400)
    Geforce 4 Mx low profile & passive cooling for multiscreen (& custom res) in my old M9000...
    Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
    May 2004
    Boston, Mass
    ^Thats a sweet setup. Any idea when that new chipset will be out?
    Computer:
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    free post!
    Quick! To the Popemobile!
  1. head unit upgrade
    By xtra in forum Car Audio
    Last Post: 09-10-2004, 10:39 AM
  2. How do you upgrade??
    By Carp in forum Media Engine
    Last Post: 05-09-2004, 06:35 PM
  3. Delorme StreetAtlas 2003 SAPI 4 upgrade
    By gfoulks in forum GPS
    Last Post: 05-08-2003, 12:03 PM
  4. Old pentium upgrade help needed
    By Holden__V8 in forum General Hardware Discussion
    Last Post: 05-21-2002, 10:24 PM
  5. can you upgrade a laptop processor?
    By etrik in forum General Hardware Discussion
    Last Post: 06-24-2000, 08:54 PM
