Results 1 to 10 of 13
Thread: do i really need more than 1 PCI slot?
    Oct 2004
    if i've got 4 USB 2.0 ports?
    I just want to make sure i'm not going to need more than 1 PCI slot, to do the majority of the things a carputer should be able to do, before i buy.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    I have another USB card in one slot for DVD(USB DVD got choppy with too much crap on the onboard USB controller sometimes), SB Audigy in another, and my wireless card in the third.
    Fabricator
    Oct 2004
    dayam... you had 3 PCI slots?!
    I guess thats the drawback with going with the mini ITX boards...
    You think DVD playback on a USB 2.0 port is choppy? Hmm... that's not good... i was hoping to use an extended USB cable to mount the DVD-CD drive elsewhere.
    Oct 2004
    i think you would need at least 2....1 for soundcard, 1 for something else you may need...like firewire or wireless
    Oct 2003
    WI
    Quote Originally Posted by ummagawd
    DVD playback was fine on one USB controller by itself, but with all the other USB crab going it got choppy sometimes. I believe the 4 or however many ports are on your MB still share the same controller, and adding a PCI USB card doubled the available USB bandwidth?
    I know I had this same problem with my old setup using the external USB Audigy - it totally hogged the USB bandwidth and everything was almost useless including the USB audio. That was the last straw for the laptop carputer.
    Fabricator
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I only use 1 pci for my wireless card, everything else is USB
    肚子笑痛了
    S60 Install
    Super Moderator xBrady's Avatar
    USA
    I have 3 PCI and 4 USBs and I only use 1 PCI for my wireless.
    Installed.
    -GPSSecure- - GPS Tracking
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    I don't even use my pci slot. I have not tested DVD yet, I must admit, but my external audigy2 NX is working fine with divx movies and mp3.
    I also have the touchscreen, a keyboard (temporary) and a GPS receiver connected to the onboard usb2.0-controller. I hope to be able to connect a DVD-rom and play dvds without hicups...
    Oct 2004
    yea my mobo actually comes with a PCMA (laptop card) for wireless (the new MII12 board)... and the only thing i plan to use for the USB is the GSP, TS, DVD and possible keyboard.
    I'm going to stick with the on-board audio.
    Newbie Proplus's Avatar
    Jun 2004
    You could always see if your case can fit a dual PCI riser card....
  1. is there a pci slot splitter?
    By emayers04 in forum General Hardware Discussion
    Last Post: 05-26-2004, 10:20 PM
  2. PCI slot extension
    By alienjj in forum General Hardware Discussion
    Last Post: 02-08-2004, 02:35 PM
  3. *one* bad pci slot? also, bad NIC?
    By InFix in forum General Hardware Discussion
    Last Post: 11-27-2002, 11:49 PM
  4. New/Old ITX 2677 Case with PCI Slot and Riser!!!
    By m3rdpwr in forum General Hardware Discussion
    Last Post: 08-12-2002, 01:28 PM
  5. Extend a PCI slot?
    By lifter in forum General Hardware Discussion
    Last Post: 12-10-2000, 06:42 PM
