Results 1 to 10 of 18
Thread: PocketPC/WinCE on a Mini-itx
    Oct 2004
    Hi all, first timer here. Has anyone here tried or thought about running WinCE or variants on a Mini-ITX motherboard? I found a motherboard called LV-670M from Commell Systems that claims to be compatible to WinCE, Embedded XP, etc.
    Jun 2003
    Kansas City, MO
    pocket pc wouldnt work on an itx because its compiled for a different processor type. pocket pc's run on the ARM processor which is a mix between x86 and a RISC processor.
    Philip Plante
    my projects:
    idgn.org | idgnonline.net | contrastsolutions.net
    Constant Bitrate RPI Geek's Avatar
    Oct 2004
    Schenectady, NY
    You can also use Windows XP Embedded if you can get a hold of it.
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
    Oct 2004
    ARM based Mini-ITX motherboard
    Found this via Google. Samsung 2410 Evaluation board
    It's a Mini-ITX motherboard that uses an ARM cpu. Not that I could easily get a hold of one, but if I did, ..I wonder if it would work.
    Newbie PCGUY112887's Avatar
    Oct 2004
    Illinois, Near St.Louis
    I can... I shall have to read into what exactelly it does...
    Newbie zojirushi's Avatar
    Oct 2004
    windows ce.net can run on a multitude of various processors. Since microsoft bumped it up to that .net designation or in 4.2 (I forget exactly when) windows ce can be used to run on x86 processors. I think the list of different supported processors is 10 or more including various arm and risc processors.
    Windows CE is being marketted as an oem development tool. I think the software tool costs 900 per license and between 10 and 50 dollars for repackaging into devices. I have the windows ce 4.2 package through my college's msdnaa program (I get microsoft stuff for free) and the sucker is 6 cds cuz it has images for like a kajillion different platforms. You can use the package to create different images for the device you are building (in our case an x86 based processor) I believe that the via boards all can be run by ce.net and the boards with built in flash readers can even boot ce from them with via's fastloader utility. (no need for ide->flash adapter thingy) Unfortunately, I don't think the fastloader utility supports xpe.
    Although the kernel for ce is called win32, it is different from the win32 in xp. Any software that relies on win32 API calls (this includes .net) will not be able to run on CE. This includes winamp and probably any of the software thats talked about on this board. When compiling code in visual studio.net, you have to target the ce API by downloading some tools via microsoft for free (too lazy to find link)
    Media in ce is not as well supported as in xp or xpe. All the codecs and whatnot that are used on xp would have to be recompiled for the ce framework. I did run across windows media player for ce or some crud like that. I didn't read too much into it, but it did not look as robust as the regular window media player and couldn't find SDK for it either.
    I am currently coding a custom frontend / UI for my carputer and I am codeveloping two versions, one to work on the CE and the other on the xp framework simply because I haven't decided which platform I want my carputer to be running although all signs point towards using xpe at this time.
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    Quote Originally Posted by kamskii
    Wow that is amazing although a bit 'snailey' it only uses 2.4 watts!! That is almost nothing but probably USB devices would use the lion's share of the power!!!
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    XP Embedded
    Quick! To the Popemobile!
    Variable Bitrate egeekial's Avatar
    May 2004
    Would there be any advantage to use XP Embedded instead of XP Pro?
    Oct 2004
    Embedded would most certainly be smaller in size, and thus should boot faster.
  1. best mini itx board
    By 2nau-t in forum General Hardware Discussion
    Last Post: 09-08-2004, 11:05 PM
  2. MINI ITX board
    By llmask in forum General Hardware Discussion
    Last Post: 07-29-2004, 11:26 AM
  3. Bargain!! Via Epia Nehemiah 1ghz Mini Itx Mainboard
    By dave0109 in forum Classified Archive
    Last Post: 05-26-2004, 07:40 AM
  4. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 09:46 PM
  5. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 04:20 PM
