Results 11 to 20 of 23
Thread: overclocking carputers
  1. #11
    Jan 2001
    Irvine, CA, USA
    Cool
    Well, I would still recommend the thermal grease and rain. It'll keep the temperatures down, which is always nice.
  2. #12
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Post
    I guess it depends on what you are trying to do in your car. My 233 with 64Megs ram plays MP3s and runs the GPS simultaneously.
    However it would really bog down with some of those fancy visuals y'all are putting on the monitor. (I can't hardly run the one that comes with winamp 2.67)
    Speaking of that the one I like best so far is the default one on Win Mediaplayer 7. (I am sure there is one like that for winamp)
    http://www.geocities.com/mr_bubba_zanetti/
  3. #13
    Sep 2001
    I ran my Celeron 300A on an Abit BH6 @ 464 MHz in the car for about 6 months and had no problems, even with very little cooling other than the cpu fan and heatsink.
  4. #14
    Apr 2001
    Here, There, Everywhere
    personally I would keep that to the desktops, and even then if your not a games junkie then why would you bother.... I would rather my PC's are stable than hot and tempremental......
    espically with the heat the car interiror can reach, overclocking should be the furtherest from your minds... !
    Project - GAME OVER :(
  5. #15
    Sep 2001
    Well, in my case, the cpu could hit 504 with good cooling...But at 464 it was completely stable, the only reason I ran it so high was to play the Final Burn emulator a lil' bit better
  6. #16
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Originally posted by Szech
    5) Once you have found a stable speed/voltage setting, go to www.tweakfiles.com and get some CPU hlt issuing program. I have Rain 2.0. It's free, it works. I don't recommend using this program while you are still finding a stable overclocked speed because it might run stable while idle, but crash when you start using it.
    This isnt necessicarily true for an older, slower chip like a Classic Athlon, but on newer chips, the programs that get around the registers in the bios can actually cause your machine to be more unstable, because of the large power demand of swinging from completely idle to full load (which is why a lot of motherboards don't allow a chip to reach "idle temperatures." And getting even further off topic, if your computer is sitting idle, you might as well turn it off I guess I never saw the point of trying to get the lowest idle temperature possible. Then again, none of my machines ever idle, they all genome @100% load 24/7.
    And this winter, i probably could have overclocked my duron significantly (as it wasnt uncomon to boot the machine, and have mbm reading -5C for the cpu ).
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
  7. #17
    Banned
    Jun 2001
    Adelaide, Australia
    Originally posted by Arby
    My t-bird 1000 is running at 1200 right now no problems, but I have 6 fans in my system.
    I also have my T-Bird overclocked from 1 to 1.2ghz.. The extra fans you have aren't nescisary.. I have no extra fans... only the standard PS and 6cm CPU one, and the system is quite stable.... The heatsink/fan is just a cheap one (for upto a 1.5ghz I think) and the cpu runs @ about 52degrees celcius.... not too hot...
  8. #18
    May 2002
    Sef'Kylar
    Yes, an athlon 550 could run at 850, but you'd need a massive cooling system.
    I OC'd my duron 650 to 900 with just a nice heafty heatsink and a good highspeed fan (not sure of the brand, someone gave them to me)
    It ran stable and under 38C(100F) when idle and never got over 50C(125F) when it was cranking.
    That fan was a noisy little thing. Still using that cpu (i ordered a tbird 1.4 but it shorted x.x) with a volcano 5 and it's fine and runs fairly cool.
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
  9. #19
    Jun 2002
    Grundy, Va
    yes myne is overclocked and yes I have a good reason to,
    my processor is a pentium 75mhz, by overclocking to 100mhz I gained only a small amount of additional heat that was more than taken care of by my case and substantally inproved the performance of my system. I am running winamp on windows 95 with an lcd plugin. My system has been rock stable and I have had no problems out of it.
    At my lvl overclocking was a great improvement however if your already running 500mhz then i doubt that you will see much improvemet.
    But yes it has been done
    Justin Stiltner
    Truck :1993 Ford Ranger Splash 4.0L
    System : Pioneer HU and Factory replacement speakers
    Puter :Pentium OCed to 133Mhz and win 95 with a whistler power inverter and crystalfontz 20x4 lcd(soon to be motorized) and winamp
    Comms Gear: Cobra 25WXST, K40 whip, Silver Streak 175, Radioshack Hyperscan Pro-2045
    95 Mitsubishi Eclipse RS: FOR SALE!!! $4000
    95 Egeal Talon Tsi AWD: Project car boostin 15 psi.
  10. #20
    Jul 2001
    The Netherlands
    I did the opposite, my celly 950 is running at 627Mhz... nice & cool...
    If at first you don't succeed.........
    destroy all evidence you tried
    for info on t6369c LCD or Presslab's powersupply check:
    http://www.namms.tk <=updated!!
