Results 1 to 4 of 4
Thread: genral amp / 12v ps question
    can I use the 12v+ feed off the power supply ( that is not in use ) to feed to the ignition control on 2 amps?.
    The reason for wanting to do this is so the amps won't turn on until the Powersupply has switched them on. Otherwise I get feedback / EV noise from the MB while it isn't on.
    bakersfield, ca
    yup, 12volts is 12 volts, doesnt matter where it really comes from. The draw on the remote wire to the amps is minimal.
    Jan 2003
    Ruston, LA
    For the remote turn on ? Yes you can.
    However, I would use a relay, feed 12v from the PS to the relay, and have
    the relay send 12v to the remote on the amp.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    just make sure you put a blocking diode across the relay pins or emf will do some nice damage to your ps.
    肚子笑痛了
    S60 Install
  1. Hooking up amp question REM line
    By Jake in forum General Hardware Discussion
    Last Post: 02-09-2007, 03:19 PM
  2. system layout configuration (amp rack) question
    By traitorhound in forum General Hardware Discussion
    Last Post: 06-18-2003, 01:24 AM
  3. Turn-off pop question
    By larstore in forum General Hardware Discussion
    Last Post: 06-07-2002, 03:50 PM
  4. seperate amp, no head unit question
    By saletel in forum General Hardware Discussion
    Last Post: 12-16-2001, 03:18 PM
  5. Easy head unit question, and PC to amp question.
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-09-2001, 04:57 PM
