Results 1 to 9 of 9
Thread: Digital WW in dash housing
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Unhappy Digital WW in dash housing
    HI Has any oneof late bought a IN DASH HOUSING from DigitallWW.
    I just got mine and as i was working on it.. and nearing the completion of the project ... figured out that the button wiring dosent match with that of the description on the HOW TO ......
    has any one worked on it lately...
    pls help
    thanx
    vicky
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    msg samc
    He did the full conversion if I remember right.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Jun 2003
    Kansas City, MO
    i did one last august, and i too had that problem. i only got the power button working tho, i had the IR port for a few days but hit a huge bump and i think the solder ****ed up
    pm me if you like.
    Philip Plante
    my projects:
    idgn.org | idgnonline.net | contrastsolutions.net
    Jun 2004
    The North, Manchester
    got one on order can let you know....
    Variable Bitrate M^ck^y's Avatar
    Aug 2004
    Melbourne
    Thumbs up
    Hi vicky_obee,
    I got one of these from Dw, and I just love it! I have and old 86 Celica and there is absolutely no room for any kind of oem style indash custom monitor. It fits underneath my head unit and does look nice(opened or closed). I was impressed with the image quality and being able to switch from VGA to RCA inputs is done easily by pressing a button on the frame. There is no remote but I can't see the use of it anyways.
    I also find that not being motorized is a great feature as whenever the cops pull me over I can close/fold it away really quickly. It is horizontally adjustable (pan left and right) which means that I don't need to press a button to adjust the monitor from glare or when my girl friend wants to watch videos.
    As for power, it auto switches to standby mode if no signal is received. What a great feature, no need to make a custom circuit to have it turned off / on automatically.
    I would definitely recommend it.
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Here we go:
    This is what your buttons look like originally:
    This is what your buttons should look like after you take everything but the buttons off. Substitute the IR receiver for the one that is in your Lilliput:
    Few more things you need to do to the button board. Cut the trace shown in the picture and attach a wire to that button. Also you need to ground the Power and V1/V2/VGA buttons as shown in the picture:
    Lastly, connecting the button PCB to the lilliput:
    A note about the button PCB: on the button PCB the last button is labeled as DOWN/-, and on the housing the last button is actually +. Diagrams above take this into consideration.
    Let me know if you have any questions.
    Thanks,
    Armen
    Dec 2003
    Thanx Armen for this diagram. Well as of now the IR dosent work ( replaced original ) do i have to do some special leg changing or is it just straight 1:1 case
    thanx
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
    Aug 2004
    Melbourne
    oops, Armen, everything going loose, again and again. I keep a screw driver handy as the in dash monitor always goes loose again. Is there a way to fix this? I don't fold the screen in neither, but only when there are cops around or in unsafe areas. It's getting quite annoying. If i don't tighten it, it would wobble when the road is slightly not even.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Try a VERY SMALL dab of loctite or similar thread locker. That should do the trick.
    Michael
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. IH001 Empty Indash LCD housing - Digital ww
    By Pabs in forum LCD/Display
    Last Post: 10-01-2004, 03:45 PM
  3. How can i fit my in-dash housing into this dash?
    By Slitha in forum LCD/Display
    Last Post: 08-08-2004, 01:14 AM
  4. Replies: 14
    Last Post: 10-14-2003, 09:25 PM
  5. Digital Dash Now Available
    By gnet in forum Software & Software Development
    Last Post: 10-29-2002, 09:29 AM
