Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Good deal on car kit?
  1. #11
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Naw man, lets say you pull up to sonic. You turn off your engine, but keep your acc on so you can listen to your carputer tunes. Then you get your food and ****, and deside to leave. You go to start, but now, you have one of two options. You can either crank it and let the carputer die, or you can wait for the carputer to shut down, crank and start, then start back up your carputer. THAT'S freakin' annoying.
    Tidder
    Try RevFE
  2. #12
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Keep in mind, that ITPS w/ one of the cheap PSU's does NOT regulate +12v. Be careful. **Sizzle**
    Quick! To the Popemobile!
  3. #13
    Oct 2004
    Quote Originally Posted by Tidder
    by die, you mean it'll actually fry it? i just figured it'd lose power for a sec, like the stereo does...
  4. #14
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Quote Originally Posted by BiohazrD
    yes it does
    and by die they mean the computer will restart itself, its not like a headunit remember it'll take a while for it to reboot (and it probably isnt very good for it either, i wouldnt recomend doing it)
    Signature: [==||========] 20% complete
  5. #15
    Jun 2004
    The North, Manchester
    ITPS spec from www.itx-warehouse.co.uk :
    4) LM-1084 LDO regulator. The LM-1084 is a low dropout voltage IC that provides further regulation for the ATX DC-DC converters or any other device in need of regulation. In case 12V regulation is not needed, the LM-1084 can be bypassed by applying a solder bump as described in fig 1.1.
    How many of you have this unit?
  1. Is this a good deal?
    By ill_ace in forum Newbie
    Last Post: 04-23-2004, 12:17 AM
  2. Good In Car solution ?
    By berniejr in forum General Hardware Discussion
    Last Post: 04-07-2004, 05:32 PM
  3. FS: Morex Car Power Regulator Kit (Brand New)
    By migel628 in forum Classified Archive
    Last Post: 04-07-2004, 12:26 AM
  4. Cant get good GPS signal in car.
    By Ricky327 in forum GPS
    Last Post: 01-29-2004, 10:28 PM
  5. Good Deal on NEW pc's for the car
    By gizmomkr in forum Classified Archive
    Last Post: 05-21-2001, 01:35 PM
