Results 1 to 10 of 14
Thread: Antennas...
    Newbie PCGUY112887's Avatar
    Oct 2004
    Illinois, Near St.Louis
    Antennas...
    Does anyone know if there is someway to MAKE or BUY an antenna that can recieve the following...
    Standard AM/FM radio
    Standard TV
    CB
    Wi-Fi (B and G)
    I know that you can buy antennas that do radio and CB... surelly there is a way to have one that recieves more than just that...
    What about those wing antenna looking things I saw on Pimp My Ride earlier this evening?
    I don't want to have a million antennas hanging from the car or start putting antennas under bumpers and inside the car...
    Oct 2004
    Lovelly I just found a similar post in another area
    Still looking for answers though...
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Yikes. That's a heck of a range of frequencies.
    AM: 0.530MHz - 1.7MHz
    CB: 26.965MHz - 27.405MHz
    FM: 88MHz - 108MHz
    802.11B/G: 2401MHz - 2473MHz
    The 802.11 stuff throws it way off, even if there were such an antenna its performance in that area likely wouldn't be very good. You're better off with a seperate antenna for that.
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    Ya would have to have 3 different antennas i would think
    Feb 2004
    San Francisco
    Just have several antennas and then put them really close together. I think there is an issue if your radio antennas are not straight up. As for 802.11 you can hide that antenna under the dash, or in the rear panel in between the speakers., it should still work great. When I was using my laptop, i just used pcmcia card, and it worked fine from the floor...kind of under the dash.
    Aug 2004
    California
    Quote Originally Posted by NovaKane
    Beware of how close you put some of them together. If they're close to 1/4 wavelength of one of the frequencies apart, then the antennas will become elements of an array and screw up your radiation patterns.
    See here to figure out how to calculate wavelength: http://esdstudent.gcal.ac.uk/TelApps...ves/sld008.htm
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    Antenna tuners DO exists.
    <> They start at $600.00
    <> They can't tune multiple frequencies at once
    <> They can't tune (for $600.00) to 2.4ghz)
    look into iCom (www.icommamerica.com)
    •Micke
    Oct 2004
    Humm... well I know for a fact that I can get an antenna that does both AM/FM and CB at the same time in the same antenna... what about those old school TV antennas that go on the back of your trunk (that when painted look just like an odd back wing)... where could I find one of those?
    Jul 2004
    VaBch VA
    I'll bet my lunch that three way antenna is a 'wrapped' antenna. and while it has one physical unit.. it's got two or more leads.
    •Micke
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Might check This. Looks interesting
    Edit: or you could stick this on the roof of your car
    肚子笑痛了
    S60 Install
  1. great website for wifi antennas
    By Nico3k in forum Wireless Communications
    Last Post: 05-03-2006, 06:54 PM
  2. Antennas on non-metallic roofs?
    By wysocki in forum General Hardware Discussion
    Last Post: 08-25-2004, 01:06 AM
  3. Illegal antennas
    By snoop in forum Wireless Communications
    Last Post: 03-07-2004, 06:38 AM
  4. How I got TV in my Car (about antennas)
    By felix99 in forum General Hardware Discussion
    Last Post: 09-12-2002, 05:38 PM
  5. Extending wireless device antennas
    By schrodos in forum General Hardware Discussion
    Last Post: 06-14-2001, 12:14 AM
