Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Relay card or IO Interface?
  1. #11
    Raw Wave
    Jun 2003
    Quote Originally Posted by jazz13
    Still not quite clear on this.
    If my power windows are negative controlled then can I do WITHOUT a relay card?
    It's just that I'm gonna be hooking up quite a number of things to it and getting a relay card with only 4 relays just isn't going to be enough.
    Are you thinking of driving the windows directly off the I/O card?
    Even if your window is negatively controlled, be very careful cause the card can only sink 2A. I dont know how your window is wired up but if you are gonna sink more than 2A from that card you will blow it.
    Ill stick with a relay to be safe, unless the window switch is only controlling a relay coil and not the windows motor directly.
    You can still buy the 16 I/O card and connect 16 relays into it.
  2. #12
    Newbie jazz13's Avatar
    Oct 2004
    Canberra, AU
    Ahh.. ok.. This is making more sense now..
    Thanks Ricky. I think you've helped me nail it.
  3. #13
    Raw Wave
    Jun 2003
    If you read the spec on their site then you wouldnt have got confused
  4. #14
    Oct 2004
    Canberra, AU
    Quote Originally Posted by Ricky327
    Well, I did and I thought I had it all under control, but then I saw their little tutorial on how to use a motor with a digital output and it got me confused.
  1. Anyone interested in serial controlled Relay/Input card?
    By Ricky327 in forum Hardware Development
    Last Post: 07-03-2006, 08:12 AM
  2. Relay card
    By withoutcomp1 in forum General Hardware Discussion
    Last Post: 10-31-2004, 07:53 PM
  3. Remote control of relay card
    By kiltjim in forum General Hardware Discussion
    Last Post: 06-28-2004, 12:03 AM
  4. Parallel Port Relay Card Assistance Please
    By rmjjensen in forum General Hardware Discussion
    Last Post: 11-16-2003, 09:33 AM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 04:50 AM
