Results 1 to 9 of 9
Thread: laptop drives - which are different
    Variable Bitrate fuctup's Avatar
    Nov 2004
    Minneapolis
    can anyone give me an idea of what laptops use the same interface for there drives? im lookin into laptop ide to regular ide adapters. any info would be nice. also i searched this but that just leads me to hours of reading.
    Nov 2004
    Minneapolis
    and does anyone know what drives fit this adapter?
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=6718450633
    what other options are there for low-power optical drives, preferably dvd, internal or not
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    That adapter is the same as the one I have for my Pany laptop cd rom. There is another type that is made for hard drives like this:
    http://cgi.ebay.com/ws/eBayISAPI.dll...717738002&rd=1
    I think that it is standardized as far as the IDE interfaces for laptop drives, since when I was shopping around they all took the same adapter. Some of the Apple stuff may be different however.
    "Protecting Privacy and Free Speech Online"
    http://www.eff.org/
    Nov 2004
    Minneapolis
    ya i found the adapter you showed, but that adapter isint for optical drives, is it? i was gona pick one of those up for my HD, but i need a low power dvd or cd drive now.
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    Laptop drives are standard IDE just smaller. Regular IDE is .1" (2.54mm) pin to pin, laptop is 2mm. They are also 44 pin, the normal 40 pins and 4 more for the power and ground. Then optcal drives added a few more pins for the audio and then they made a smaller optical standard with a tiny connector (something like .5mm between the pins). I local PC shop here sells the 2.5" laptop to 3.5" desktop IDE adapters for $10, this includes the little PCB with the connectors and the mounting rails.
    Nov 2004
    Minneapolis
    im not sure if this make a difference, but i meant i need an adapter for a laptop optical drive, not hard drive, to normal ide
    May 2002
    Ohio
    Read my post again. There are two standards for laptop optical drives, one that matches the hard drive and the newer one. You have top know which you have to get the right adapter.
    trdcpu's Avatar
    Feb 2004
    Colorado
    i cant get my samsung slimline dvd/cd-rw to open up, its brand new. not sure if im powering it right
    http://www.newegg.com/app/ViewProduc...151-053&depa=0
    trdcpu's Avatar
    Feb 2004
    Colorado
    figured it out, stupid adapter screws were holding it in, sob
  1. Help with laptop drives.....
    By SinnerG in forum General Hardware Discussion
    Last Post: 05-04-2004, 01:57 AM
  2. Laptop hard drives
    By djmickyg in forum General Hardware Discussion
    Last Post: 04-19-2004, 01:57 AM
  3. using laptop drives for the carputer
    By borntorun in forum Newbie
    Last Post: 03-14-2004, 06:14 AM
  4. Are all Slim dvd laptop drives created equally?
    By afr0puff in forum General Hardware Discussion
    Last Post: 02-22-2004, 05:36 PM
  5. HARD DRIVES IN COMPOSITE BAYS - laptop
    By SOBIL in forum General Hardware Discussion
    Last Post: 08-16-2003, 03:19 AM
